closest y-pipe for Hooker 2460
Car: 1982 Z-28
Engine: 383
Transmission: Turbo 350
Axle/Gears: Det. Posi, Superior Axles, 3:73 G
Hi all,
MY question is I have a set of Hooker Headers p/n 2460-1 and to get a customer y-pipe made it will not be mandrel bent. I was thinking of buying a SLP or other brand name y-pipe that is completely mandrel bent and just cutting off their collectors and welding on the Hooker collectors. My question is , are there any y-pipes that are close to the fitment of the hooker headers and only slight modification (cutting & welding) of the two pipes going to the headers out there? I looked at the SLP and was thinking it may work. I'm just wondering if anyone had done this, has noticed that certain y-pipes come close to fit these headers but don't without mods...any help would be great. Thanks.
Transmission: 4L80E/4L80E
Find another shop that will do mandrel bends. By the time you bastardize the SLP pipe, you'll have as much spent as you would have by having a real shop mandrel bend you a real y-pipe.
Just curious, why did you go with the 2460's instead of the 2055's, which come with a mandrel-bent y-pipe?
Car: 1982 Z-28
Engine: 383
Thanks five-7, I'll look around and see if I can find a shop that'll do that. All I found so far are exhaust shops that do non-mandrel bends.
I got these headers dirt cheap and they are ceramic coated.
Thanks again.
Thanks again.
no green
Jan 9, 2016 09:22 PM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
