Side running exhaust ???
Old Jun 29, 2002 | 06:38 AM
Red_Dragon_X's Avatar
Ok guys i have a couple of questions for you.
1) i want to put in a new exhaust system in my '84 camaro and i was thinking of shootin it out the side(i think that looks NICE). just wondering if there is any major problems i should know about before i get my heart set on this, and also if anyone knows a good site to walk me through it (though ill bet you guys have a tech article on it!!)
2)im runnin a little 2.8 right now but i dont have the money to spend to drop in a 350 like i want to, but i do have some extra cash to work on the exhaust right now... when i do get the money for that engine what will i have to do to make sure that the exhaust system i set up now will be able to set up to the new one ?
thanks for all the help ... you freakin genious people !
-RDX
Old Jun 29, 2002 | 09:59 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
If you have gfx, I would worry about clearing them. Also, depending on your local emission laws, most places it's illegal not to have the exhaust exiting past the rear tires.
Old Jun 29, 2002 | 08:27 PM
Rage13's Avatar
Car: 89 Firebird
also clearance may be a problem, a guy near me has a bird he did that with, but changed it do to clearance problems (speed bumps mostly) but he mite have lowerd the front end, not to sure..
Old Jun 30, 2002 | 09:48 AM
ok thanks for that info guys ... i wasnt even thinking about that. well i think that im gonna scrap that idea and just go with i nice hooker system ... but is there anything that i need to know about putting in the 350 with the mods i want to do now?
Old Jun 30, 2002 | 01:08 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
carndrv did it to his car. i have a pic but absolutely no details
Old Jun 30, 2002 | 09:05 PM
KiLLJ0Y
Guest
Posts: n/a
a guy that used to live on my street did this... BUT
heres the thing... you'll need to 90-92 GFX's... cause they hang lower... looks better.. anyways.. to do it properly and still look cool and have some reasonable ground clearance.. you'll have cut a rectangualr or oval whole in the GFX's...
just like on Roush Mustangs. they use a special tip that helps prevent the paint from being heat blasted..
its looks awesome when done..
Old Jul 4, 2002 | 01:45 AM
Gta-Paladin's Avatar
what rims are those
Old Jul 4, 2002 | 02:08 AM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
i have a 91 gta and i would really love to have dual side exhaust (someone said like the mustangs have )....would it be possible to go THROUGH the gfx's or would i have to go under them...i really like the way that blue camaro looks...im gonna go look at my car in the morning and take a good look
later guys
Old Jul 4, 2002 | 01:15 PM
easySPEEDcamaro's Avatar
Car: 1992 Camaro Z28 Anniversary Edition
Transmission: Borg Warner 5-Speed
just thought i'd add some pictures of cool side pipe exhaust!
Old Jul 4, 2002 | 01:16 PM
another one
Old Jul 4, 2002 | 01:25 PM
last one
Old Jul 4, 2002 | 03:26 PM
Nitroburn's Avatar
easySPEEDcamaro, that is S W E E T ! ! ! ! Nice job!!! I'm guessing that you're not running cats.
What is your clearence like with the mufflers mounted where they are? Any probs with speed bumb?
Also, how does it sound?!?!?! :rockon:
Later,
Mike
Old Jul 4, 2002 | 04:02 PM
KiLLJ0Y
Guest
Posts: n/a
if you arent worried about clearence... this set up is good.. but.. if you are like me and have low pro tires and sportline springs.. its not cool...
but if you are still worried about clearance.. you can help it out by using Oval tubing (i saw a thing for it by Spintech in CHP mag) what also might help is one of their mufflers.. i know it is rectangular shaped and accepts oval pipes... or you can use a bullet muffler from Dyno-max. theres alot of options out there.. but my moto is " if you;re gonna do it... do it right... if you're gonna do it right.. do it right the 1st time"
sucks when you have to go back and re-do thing.. research what you wanna do.. anything is possible.. just dont rush anything and im sure it will kick ***.
Old Jul 4, 2002 | 09:24 PM
VampireHunterC's Avatar
What about exhaust fumes, with the windows down and/or up?
Old Jul 5, 2002 | 06:47 PM
those pics look real good but im really concerned about that clearance ... i dont know how many of you guys live in new york but the roads out here are terrible ... if you were to hit a pothole at anything more than 3 MPH you'd probably lose that thing. i really wanted it cause it does look good, but i have no faith in the ground clearance.
Old Jul 6, 2002 | 09:59 AM
jerflash's Avatar
Car: 90 Formula, 02 ws6
Engine: 305 tpi, ls1
Transmission: 700r4, t-56
Axle/Gears: stock posi 2.73, 12 bolt with 4.11s
i must agree it look really cool and i bet sounds just as good but new york streets would eat that thing up
Old Jul 6, 2002 | 01:54 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
I've got the same exhaust set-up as easystreet, but not nearly as pretty-race car, anyway clearance sucks. When I have a full tank of fuel and a passenger the ants on the road have to duck. I'm surprised my muffler has'nt got a hole worn through yet, it's nice and shiny in that spot. When I swap in the new tranny I think I'll either buy the 3/4 length headers or maybe opt for the hookers so I have more options on exhaust routeing. The full tube Heddmans just don't cut it. A fella here in town said he runs 3.5" single on all the 3rd gens cause there's just not a practical way to run duals inexpensively.
Old Jul 6, 2002 | 11:32 PM
bluemeanney's Avatar
easy true duals.......
the easiest way i have thought of seems to be with either hooker lt, or heddman lt, and the s bend from heddman angles it toward the driveshaft. you may have to angle it more, but use a bullet muffler and the oval tubing from spintech to make a 90 out to the side. with heddmans it will cost about 350 bucks.
Old Jul 7, 2002 | 12:34 AM
Tas's Avatar
Tas
Originally posted by Gta-Paladin
what rims are those
Boyds' "tuned"
http://boydcoddington.com/
Vintageracer
Jan 10, 2020 05:33 PM
transaero
Aug 31, 2015 01:14 AM
db057
Aug 22, 2015 08:17 PM
timonator
Aug 11, 2015 09:56 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
