Getting 2055's, Should I get different gaskets/bolts than the kit comes with?
Old Jul 1, 2002 | 08:20 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I am getting coated hooker shortie's with a catco cat and wanted to know if I should get better bolts and gaskets than what comes in the kit. I do not drive my car year round, if that makes a difference. I thought about dead-soft gaskets and locking bolts.
Old Jul 2, 2002 | 07:56 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
The heads-to-header-flange gasket that came with the 2055's is one of my two nits against them. The openings are smaller than the ports, and they look like cheap cardboard. I wrote Hooker about the small openings, their reply was something to the effect, "The part that sticks into the port will burn out pretty soon, so it isn't a problem." That's confidence-inspiring, header gaskets that burn quickly.
World recommended Fel-Pro 1404 gaskets with their heads, so that's what I got.
I didn't have any issues with the supplied bolts.
Old Jul 2, 2002 | 08:28 PM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
I got percy's dead soft aluminum gaskets and stage 8 locking header bolts for mine. The gaskets that come with it are crap. The bolts would probably be fine, but I did it just to be on the safe side. Once I get them in, I don't want to have to take them out again to replace a gasket due to a bolt that worked loose. The gaskets were ~$30, and bolts were ~$30 also from summit.
1Aauto
Sponsored Vendors
Feb 8, 2017 03:09 PM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:25 AM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
