Can't get smog pump out!!
Old Jul 26, 2002 | 10:44 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I took off the pullyand I see the screws that need to be takne out but when I went to unscrew them they wouldn't budge and I started to strip the head out. What is the easiest way to get this out without stripping those stupid screws?
Old Jul 26, 2002 | 11:00 AM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
are you talking about the torx bolts
Old Jul 26, 2002 | 11:39 AM
TheLG4Whore's Avatar
Car: '86 Trans Am
Transmission: TH700R-4
Axle/Gears: 10 bolt 3.73
If you like playing with fire then you could just get an oxygen torch and cut it off.:rockon: :rockon:
Old Jul 26, 2002 | 04:04 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
yes i am talking about the torx bolts. What would happen if I put the pully back on tand ran the smog pump with everything disconnected from it? Would it sieze up?
Old Jul 26, 2002 | 07:33 PM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
I'm with TheLG4Whore on this one...
Old Jul 28, 2002 | 12:35 AM
HrdRockA4305's Avatar
My ranting about a similar situation:
https://www.thirdgen.org/techbb2/sho...ight=torx+suck
I've ripped the threads off 2 bits so far, I bought a 3rd, craftsman this time, they were sold out before. Maybe this one won't strip. I haven't had time to try again yet.
Old Jul 28, 2002 | 09:05 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Well the bit that I used didn't strip it was the bolt head. My tool is okay i just rounded off the star pattern in the bolt head. and I don't have time or a car to go get one of those screw remover thingys from craftsman.
italiano67
Dec 11, 2016 09:21 AM
J.C. Denton
Aug 31, 2015 03:11 AM
Victor6
Aug 30, 2015 02:09 AM
camaro_rs350
Northern California
Aug 18, 2015 12:38 AM
mustangman65_79
Aug 7, 2015 09:55 PM
