Help me put the collectors together for my headers?
Old Jul 27, 2002 | 01:24 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
The kit came with two reducers, two .25" collector spacers (maybe), and 4 collector gaskets. How do these go together to make a good seal. Does each header use 2 gaskets around that spacer thing? The instructions are useless. Also why is there a reducer when the header is 2.5" and the collector is 2.5"?
Attached Thumbnails Help me put the collectors together for my headers?-mvc-008fn.jpg
Old Jul 27, 2002 | 04:09 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
stick a gasket between the spacer on each side. i dont know why there is a spacer, i have never seen anything like that
Old Jul 27, 2002 | 04:42 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
The funny thing is, I wanted to get really good collector gaskets to replace the crappy ones that come in the kit. I I ordered some from Summit and they sent me those stupid spacer things. That spacer can't be a gasket can it. It is not soft so it is not like it will squeeze down and create a seal.
Old Jul 28, 2002 | 11:24 PM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
Those "spacer" things are the gaskets. They're made out of dead soft aluminum and will conform to the collector once they get heated up. I have the same thing. Don't put the other gaskets on there though, or it will probably leak, they're junk.
Old Jul 29, 2002 | 12:15 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Looks to me like the flange that holds the reducer up to the collector. It is steel, correct? (check it with a magnet if you aren't sure) If so, then you put it on the reducer, slip it up to the expanded part, put the gasket between the reducer and collector, bolt it together.
The reducer is intended to allow you to hook the header up to the rest of the exhaust system.
Of course, I don't have a clue what headers you've got, but that's what I've seen with every set I've had to date, up to but not including the emissions-legal ones w/y-pipe I put on the Camaro.
Looks like you also have a y-pipe, though, so you don't need the reducers. Keep 'em for possible future use, or toss 'em.
Is it possible these are Hedmans, with their y-pipe? They sell the hedders and y-pipe seperately, so even if they arrived together, the hedders will have the reducers that aren't required when the y-pipe is used.
Old Jul 29, 2002 | 07:55 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
No they are flowtechs with 2.5" collectors and 2.5" y-pipe. That is why I don't understand why they have reducers. I didn't use them and I far as I can tell i don't have any leaks yet.
Old Jul 29, 2002 | 12:19 PM
iroc22's Avatar
If you used any of the supplied gaskets, you'll be in for a surprise in about a week. You gotta go with Mr.Gasket or Felpro gaskets.
Old Jul 29, 2002 | 01:36 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Yea I am aware of that. See I got mixed up. I ordered what i thought were collector gaskets from summit and when they came here I realized that they were just those aluminum spacers. They even called them "collector gaskets" and no they are not dead soft. They are made from .125' aluminum. When I do get the copper or dead soft should I get 4 and still use the supplied spacers?
Old Jul 29, 2002 | 06:26 PM
kfoley's Avatar
Car: '85 Z28
Those are collector gaskets. They aren't literally "dead soft", that's just what they call that type of aluminum since it is very soft. I have the same gaskets, except that they're from flowtech.
Street Lethal
Apr 30, 2019 12:14 PM
Wvcamaro
Sep 4, 2015 08:38 PM
theurge
Aug 21, 2015 12:46 PM
beast94
Aug 20, 2015 06:44 AM
sreZ28
Aug 14, 2015 07:48 PM
