Heddman Y pipe ?
Old Jul 28, 2002 | 12:17 PM
88Roc350TPI's Avatar
Heddman Y pipe ?
Hey all,
I traded my Iroc for another Iroc that's much better, anywho...this one came with Heddman Hedders on it with their Y-pipe and has what looks to be a slip joint right where it passes under the oil pan. Do you know if this is supposed to have a clamp or gasket or anything in or on it? It looks like it's leaking a little and I wanna stop the leak.
Old Jul 28, 2002 | 12:25 PM
TwiztedZ28's Avatar
Ive got the heddman headers with that y pipe on my iroc and when they put mine on they welded that slip joint together. Mine doesnt leak but im sure a band clamp or weld job would help your problem.
Old Jul 28, 2002 | 12:55 PM
TexasLT1's Avatar
Car: '92 RS
definitely weld it, but make sure everything is already bolted up and lined up right, or else its a complete pain to bolt the headers to the y-pipe. somehow the alignment is off on mine and it takes a while to bolt up because you have to pull the y-pipe into line with the header. I think it may be the cause of my exhaust leaks, I never can seem to get rid of them.
Old Jul 28, 2002 | 10:06 PM
johnyIROC's Avatar
I just installed the hedmans with the hedman Y pipe, and we welded the slip joint. It was one of the easiest mods I've ever done. The headers dropped right in from the top, didn't have to lift the engine or anything.
Old Jul 29, 2002 | 11:46 AM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
I have mine clamped on. I probably should weld it but I'm getting rid of it once I get the car running again.
I've been throwing around the idea to my "exhaust welder-up-er" friend about cutting the hedman y-pipe just before it turns into a single pipe and then welding up duals that follow the stock route next to each other. Then about 3 feet before the axle have them branch off into an H and dump at the rear. Who knows, gotta do some more measurements.
Old Jul 29, 2002 | 12:12 PM
johnyIROC's Avatar
That's crazy talk
Old Jul 29, 2002 | 12:26 PM
TheLG4Whore's Avatar
Car: '86 Trans Am
Transmission: TH700R-4
Axle/Gears: 10 bolt 3.73
I still need my Y-pipe.
Gotta love those heddman's they are soo cheap and they get the job done well enough.
Old Jun 24, 2003 | 08:03 AM
bigals87z28's Avatar
Car: Check The Sig
ok im set... 2 NJ people have it on there car... im getting the coated ones (the elite ones?) and the y pipe.. anyone get theres WITH a O2 sensor in there headers or ypipe or did you get it put on at a shop?
Old Jun 24, 2003 | 11:43 AM
deepstage69's Avatar
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
i had to weld mine in.
Old Jun 24, 2003 | 02:24 PM
Formula383's Avatar
Car: 88 Firebird Formula
Got mine Hedman Hedders from Jet Hot. It came without the O2. I spoke w/ there Tech support and there are going to put the O2 bung on for free. If you are getting them coated from Jet Hot make sure you ask if the O2 comes on it. If not tell them to weld it on. Seems to be that Hedman for got to put them on for certian hedders.
Old Jun 24, 2003 | 08:40 PM
Car: Check The Sig
see, now i got this from jegs... tell me im not getting mixed messages here?!?! i think im gunna order the cat and cat back then next week order the headers and y pipe
Old Jun 25, 2003 | 02:14 PM
Formula383's Avatar
Just make sure when you order them, ask them to make sure the O2 is there.
Old Jun 26, 2003 | 02:46 AM
2 dope's Avatar
Car: 1985 Camaro Z 28
Engine: 305 LG4
i read that you shouldnt clamp the y-pipe coz it could hit the oil pan, a regualr clamp that is...best to weld it
Old Jun 28, 2003 | 07:56 PM
XThree's Avatar
Car: 91 RS
Transmission: TH 700 R4
they might go in easy but how did you get the stock manifold off the passenger side? unless you have removed the AC, and fan blower. I'm putting on hedman headders and Y-pipe on a 91 RS with AC and its nearly impossible to get the back bolt out with that Fan blower unit there.
Old Jun 28, 2003 | 10:39 PM
TransAmTBI's Avatar
Engine: 305 TBI
Transmission: th700R4
i literally just put my hedders in today and to get that back bolt yo must un due the motor mount and jack up the engine..
my headders were easy to put in the only thin ki had to move was the stering shaft had to be unbolted..def easier than i expected tomorrow thw y-pipe.
Night rider327
Oct 9, 2015 09:25 AM
LT1Formula
Oct 8, 2015 08:34 PM
