Please help! Cat conv hot as fire.
Car: 82 Trans am
Engine: Twin turbo 350
You probably are running really rich/lean. The catalyst in the converter has to work overtime to convert the exhaust gases to co2 and h20, and makes excessive heat as a by-product. in a normally running engine, the cat only has to do a small amount of work, and the heat produced is negligible. i would take a look with a wide band o2 and see whats going on with the mixture
slickrock55
slickrock55
Car: 99 Formula
Axle/Gears: 342
Yep, probably runnin a little lean. Check the timing and choke (forgot to check your sig) so that may not be a problem.
Red hot, as in it glowing right?
[Sold] Flowmaster exhaust system
Night rider327
Oct 9, 2015 09:25 AM
Night rider327
Sep 25, 2015 04:47 AM
