What headers and Y- Pipe are best for me?
Please look at my sig to see the specs to my car. I want headers and a y pipe. I think I would like to get ceramic coated headers....but I DO NOT need the Y pipe ceramic coated. I wouldn't mind having to pay somebody.....to get the headers ceramic coated. I would like a shorty-type header that will not give me any ground clearance problems.....like longtubes may. Also, I need an oxygen sensor.....but prefer NOT TO HAVE the A.I.R. I have heard about reducers that come with the oxygen sensor bung (So, maybe that could work....if I needed to). Lastly, I want to hook up to the factory, single catalytic converter......which getting a shop to bend me a custom one is an option. Thanks in advance for all the help and comments!
Car: 1989 Camaro IROC-Z28
Engine: D1SC Procharged 350
Transmission: D&D Performance built T-56
Axle/Gears: Moser 12-bolt 3.90
Hooker makes a shorty header with a y-pipe that you can get coated...I'm not sure of the part # because my friend has my Holley catalog. You ought to try out thier website @ www.holley.com
I don't think that you can get these headers without the A.I.R tubes though.
Transmission: 4L80E/4L80E
Hookers with the y-pipe and coated are 2055-1. They do have A.I.R. and O2. The y-pipe will be coated if you order them using that p/n.
Hooker has 2460-1 that will be shortie headers but no y-pipe is available for them. You can order them with the O2 bung. You'll have to have a y-pipe fabricated.
Order either of the above without the -1, they'll come uncoated, and you can ship the headers off to Jet Hot and have them coated.
Hedman has shortie headers and y-pipe that you order seperately. You can buy the headers coated but not the y-pipe, or send them out like above.
Is cost the reason you don't want the y-pipe coated? It's actually not a bad idea to have it coated. Corrosion protection will be much better, and heat to the oil pan and floor pan will be reduced.
Car: 90 Formula, 02 ws6
Engine: 305 tpi, ls1
Transmission: 700r4, t-56
Axle/Gears: stock posi 2.73, 12 bolt with 4.11s
flowtech shorties all the way
it is $200 for headers and y-pipe and they fit better then most systems that cost twice as much
they are a direct replacment for your stock stuff
they dont have air tubes
they are 1.5 primary size and 2.5 y-pipe size which is perfect for your car
i have them on my 305 tpi and they made a hell of an improvement in both sound and performance (allot more power)
i run them with no smog, no cat, and stock tpi 2 3/4 exhaust and a flowmaster 80 it sounds so good
this is the perfect budget header set and you can have the headers coated for an extra 100
i recomend these headers coatedwith no cat and flowmasters american thunder cat back
you cant go wrong
you cant go wrong
Car: '85 Z28
Transmission: WC T5, 3.23 posi
You can also order the hooker supercomps (pn: 2055) straight from jet-hot and they're already coated. I'm not sure if you can order the y-pipe from them or not, but I would imagine you could.
LT1Formula
Oct 8, 2015 08:34 PM
