Emissions? What are those?
Old Aug 17, 2002 | 12:50 PM
bubbz89's Avatar
Car: 1990 RS
Transmission: TH-350
i am going to cut my cat off monday, and i am thinking about buying some headers. i am not to savvy on how the whole a.i.r system works though. will i throw a code by removing my cat? if i just order headers that dont have air tubes, would it be okay. do i have to remove the air pump? emissions are not a problem, so any advice in this area would be great. tia.
Old Aug 17, 2002 | 01:05 PM
Ratstix's Avatar
when you remove the cat just bust the AIR line off that goes to it.
then when your taking off the stock maniflods to put on your headers, take all the air lines off of them, follow them up to the pump removing any brackets along the way, then once at the pump simply disconnect it.
and if you would like to remove the pump also, do a search for "remove smog" or "remove AIR" and you should find out everything you need to get rid of the pump (belt #, belt routing, etc)
Old Aug 17, 2002 | 01:30 PM
bubbz89's Avatar
Car: 1990 RS
would it hurt anything by just leaving it on there for now? what kind of power increases are normally seen with headers and no cat? thanks!!
Old Aug 17, 2002 | 04:45 PM
ninety1TAgta's Avatar
It tells you how to remove the smog pump in the modifications section on thirdgen.org... not to hard but I hope you dont get a visual emissions check down there
Old Aug 17, 2002 | 07:31 PM
bubbz89's Avatar
Car: 1990 RS
the only thing they check is wipers, lights, horn, tire condition, winshield. thats mississippi for you!!!
Old Aug 17, 2002 | 08:22 PM
And thats bad?!?! I would love that. My car wouldve shaved 100 pounds the day I got it.
Old Aug 17, 2002 | 08:41 PM
bubbz89's Avatar
Car: 1990 RS
i did not mean its bad, i just live like 3 miles from memphis, tn where you undergo the sniffer once a year. well, since i moved down here, i figured it is time to pollute a little.
Hotrodboba400
Dec 10, 2019 07:07 PM
racereese
Oct 3, 2015 03:46 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
TBRays98
Sep 6, 2015 05:05 PM
