Replacement muffler? Hooker, Flowmaster? what?
Old Aug 26, 2002 | 05:09 PM
jd13's Avatar
Going to be getting rid of this crappy 80 series flowmaster very soon. Just need opinions on a muffler to get now.
I don't want it to be real loud, has to sound good, but also perform well. Doesn't have to be dual outlet either. Will a single 50 series flowmaster work? Hooker? Borla? I'm not sure.
Old Aug 26, 2002 | 08:11 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
If you dont want real loud, and kinda quite until WOT, go with Hooker
Old Aug 26, 2002 | 09:15 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Hooker.
right click save as. http://us.f1.yahoofs.com/users/5b624...u.ua9AQY7bFI_9
Old Aug 26, 2002 | 11:15 PM
LastViceRS's Avatar
Car: '91 RS
Engine: LO3, For now...
I'm going with Hooker. If you want to hear a contrast between WOT and part throttle, click on Mark's "Hooker CatBack sound clip with old mods". He nails it through the first couple of gears, then just cruises through the next couple. Comparing that with a couple of FlowMaster clips (not that there's anything wrong with FlowMaster, just personal taste) helped me decide.
Old Aug 27, 2002 | 01:34 PM
jd13's Avatar
I was looking at the two chamber flowmasters, but I wanna keep the dual tail pipes in the back. So Hooker it is
I've looked around, but I'm not really sure what Hooker muffler that I need?
Old Aug 27, 2002 | 03:59 PM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
I hear the Dynomax isn't too loud. I'm ordering mine this week, so then we'll see.
Old Aug 27, 2002 | 04:02 PM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
Ahh, wheres all the old Flowblocker boys at?
Man its been a while. I see Mark is still the same.
Old Aug 27, 2002 | 04:15 PM
Fast3rdGen's Avatar
flowmaster
i would stick with the flowmaster........and if they are so called "flowblockers" then obviously you have taken a look under drag cars that require mufflers....if you don't see a dynomax race muffler you see a flowmaster most of the time......i went to the fastest streetcar shootout in columbus and 9 out of 10 cars ran flowmasters of some sorts (the guy that one this year was running low 8's at 170+mph with yes....you guessed it....flowmaster mufflers)....so put that in your crack pipe and smoke it lol. :hail:
Old Aug 27, 2002 | 04:48 PM
Car: 91 RS
Engine: 350 TBI
Re: flowmaster
.....well then....
Old Aug 27, 2002 | 05:22 PM
Fast3rdGen's Avatar
i'm sorry......i guess you could say i'm a Flowmaster activist lol
Old Aug 27, 2002 | 07:21 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
What don't you like about the 80 Series?!
Old Aug 27, 2002 | 08:01 PM
IwantanFbody's Avatar
Hey mark, i keep hearing people say the hooker cat back is really quiet at idle. on your clip it sounds pretty loud. is it louder than i think or were you holding the mic right up to the tip? thanks
Old Aug 27, 2002 | 08:57 PM
Car: 99 Formula
Axle/Gears: 342
Which file did you listen to? The hooker 350 is with my old mods, and the cam really woke the sound up at idle. But the mic is hanging out the hatch with both files.
Old Aug 27, 2002 | 08:58 PM
i am talking about your old one.
Old Aug 27, 2002 | 08:59 PM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
They're really quiet at idle, but when you get on it they scream.
Old Aug 27, 2002 | 09:00 PM
thats what i have heard a billion times, but listen to his old clip. it sounds louder than "really quiet"
Old Aug 27, 2002 | 09:45 PM
jd13's Avatar
Maybe I got a bad one. But right in the 1500-2000 rpm range it sounds like a golf ball rattling around inside. It's very loud inside the car and quite noticable outside. I can't stand it. I know the muffler flows well, but that sound is waaaaaay too much.
edit: Oh yeah, what's the Hooker muffler with single 3" in and two outs, I can't find it anywhere?
Old Aug 28, 2002 | 08:12 AM
Dan94GT's Avatar
flows sound like *** on thirdgens IMO. I just installed a hooker catback and love the sound.
Old Aug 28, 2002 | 09:18 AM
Mohammed's Avatar
Car: 88 IROC-Z
Transmission: 700-R4
DynoMax Super Turbo outflows Flowmaster and sounds real good :hail:
Old Aug 28, 2002 | 11:48 AM
Fast3rdGen's Avatar
thats because most people stick them on a pretty well "stock vehicle.....a weak @$$ cam in a weak @$$ motor will make for a weak @$$ exhaust note
Old Aug 28, 2002 | 11:58 AM
Fast3rdGen's Avatar
i'd have to throw up a big on that one.......i went faster in the 1/4 with ONLY changing from a dynomax super turbo to an 80 series flowmaster.....weather was the same, same tires, good traction when i had the dynomax but i spun a little with the flowmaster. that, i would have to believe, would mean i had an increase in power. so much for the "Super Turbos outflow flowmaster theory".
Old Aug 28, 2002 | 01:44 PM
Js92RS's Avatar
Car: '92 Camaro RS
Engine: 355 TPI
Transmission: Tremec T-56
Axle/Gears: 10 bolt/3.42
keep in mind that opinions are like a-holes, everyone has one. It is all a matter of personal preferrence. One guy might like the sound & looks of the hooker & one guy might like the sound & looks of the flowmaster. I opted for the Flowmaster system because I did not like the tips on the hooker system (2 tips on each side). As far as one system outflowing the other, I dont think that it would make that much difference unless you are trying to squeeze every bit of HP out of your engine and trying to break the land speed record.
Old Aug 28, 2002 | 01:49 PM
Mohammed's Avatar
Car: 88 IROC-Z
The super turbo uses through pipe stile with a mandrel bended S type from the inside Flowmaster uses chambered stile so how come it flows better
Old Aug 28, 2002 | 02:17 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
You went faster, or you went quicker? There's a big diff there.
I believe that you will gain a little more flow from a Flowmaster simply because the Super Turbo is not available in a 3" inlet. It's 2 1/2" in/ two 2 1/2" out. The Flowmaster is 3" in/ two 2 1/2" out. That can make a big difference IF, and only if, you are running the 3" pipe with the Flowmaster. If you slap a 3" Flowmaster on a 2 1/2" pipe, I boubt that you'd gain but .05 of a second. But that's just my theory.
The "Super Turbo outflows Flowmaster" may be true if you're comparing a standard Super Turbo (3" in/3" out) against a 3 chamber Flowmaster with the same in/out size. But with the crossflow design, let's just face it, it don't flow worth a crap. WAY too many bends and interchanges, plus a reverse of direction, to flow very well.
Just get a Flowmaster, Dynomax, or Hooker 1in/1out muffler if you want the best flow at lower dBs. That's what the Stage 2 exhaust that comes on the 2002 Camaro SS from SLP is. They did that for a reason.
AJ
Old Aug 28, 2002 | 03:36 PM
Administrator
Because Flowmaster flows better.
Really, if you've got power, nothing sounds like Flowmaster, and even sometimes when you don't they still sound nice.
Old Aug 28, 2002 | 05:09 PM
Fast3rdGen's Avatar
AJ
BOTH....et was lower and mph was faster. it wasn't by a whole lot but i did run quicker and faster. as far as the size difference.....i went from a 2.5" dynomax super turbo x-flow to a 2.5" 80series. they make 2 sizes in the 80series. i was also using a 2.5" mandrel bent intermediate pipe with both mufflers
not that it is really relevant to me anymore because i now have dual exhaust with two 2chamber flowmaster 40 series.
i didn't mean to get anyone's panties in a bunch. i was just making my piece sharing my experience of proving wrong, the claim that dynomax makes of producing more power and torque than flowmaster. i personly liked the sound of the dynomax. it was not until i heard some of my friends race/street cars that ran duals with 40 series that made me fall in love with the flowmaster sound. and i also agree that the 80 series sounds like crap on a basically stock vehicle. i believe they were designed to work with big cams that are really on the hot side with more durration. it all comes down to whatever makes you happiest. i like the sound of just about every cat-back made for f-body's with the exception of borla. so go with what you like and can afford. sorry for any raise in blood pressure i have caused or grey hairs i have produced lol
Rich
Old Aug 28, 2002 | 09:16 PM
Car: 99 Formula
Axle/Gears: 342
hooker.
Vintageracer
Jan 10, 2020 05:33 PM
Navy8125
Aug 25, 2015 08:25 PM
midias
Aug 22, 2015 01:42 AM
makaveli09
Aug 12, 2015 09:07 PM
