how can ihave my car sound like this...
Old Sep 8, 2002 | 07:36 PM
burnouts4ever's Avatar
how can i keep my exhaust being as loud as it is having just back to the catalytic converter if i run an exhaust? what kind will i need to run?
Old Sep 8, 2002 | 08:43 PM
Hg's Avatar
Hg
Car: '87 Z
Engine: 355 in the works
ok, i'm not quite sure what you're saying.... you want full exhaust but right now it's just straight pipe with the cat, and you don't want to lose the sound it has now?
Old Sep 8, 2002 | 09:02 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
no offence, but to me straight pipes on a stock sbc sound like the worlds largest exaust leak. Go get a nice cat back. You wont **** everyone off and itll have a nice deep rumble to it.
Old Sep 8, 2002 | 09:08 PM
im thinking flowmaster 80 series will it give me the sound?
Old Sep 8, 2002 | 09:24 PM
Car: 88 Camaro SC
Engine: SFI'd 350
flowmasters sound a little hollow on stock motors. I hear real good stuff about Hooker cat backs. Go PM mark shields. He has one and he'll be glad to tell you all about it.
Old Sep 8, 2002 | 11:46 PM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
I'd say go for the hooker. Kinda quiet at idle, but loud when you get on the gas. It's $200 at summit with a little fabrication or $260 for a bolt up.
Old Sep 9, 2002 | 12:50 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
ROTFL :sillylol:
Flowmaster.
Old Sep 9, 2002 | 11:24 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Originally posted by IROCZTWENTYGR8
ROTFL :sillylol:
Flowmaster.
Hey, I like my Hookers and you like your flows.
Sound clip in the sig.
Old Sep 9, 2002 | 05:58 PM
DakotaSLT's Avatar
I have the flowmaster American Thunder on my car, and it sounds beautiful. Nice and deep at idle, then roars when you get on it. I recommend it highly.
Old Sep 9, 2002 | 07:22 PM
Black91Z28's Avatar
Car: 1991 Camaro z28
Engine: 350 Tpi
Transmission: 700r4 Auto
hollow? ummmmmm is that a bad thing?
Old Sep 9, 2002 | 07:47 PM
Administrator
Yes!!
Old Sep 9, 2002 | 08:27 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Me too
Flowmaster :hail:
Old Sep 9, 2002 | 08:40 PM
whats difference between running stock pipe with a flow 80 and having the american thunder? wont it sound the same?
Old Sep 9, 2002 | 08:47 PM
Car: 99 Formula
Axle/Gears: 342
It will sound louder with the 3" i pipe that comes with the cat-back.
Old Sep 9, 2002 | 09:17 PM
if my car has stock size cat how will 3 inch catback system work? how would it plugin? wont it produce the same hp tho as the flowmaster 80 with stock pipe?
Old Sep 9, 2002 | 09:59 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
imo, do the exhaust from the headers to the back of the car all at once.
Old Sep 10, 2002 | 09:54 PM
DakotaSLT's Avatar
My 3" I-pipe bolted right up to the cat, but I do not think it is the original cat. Check under your car, as long as the cat is the bolt-up type with flanges it should bolt up fine, I know it did on mine. The larger I-pipe gives a slightly better sound and is maybe good for 1-2 hp, but not noticeable. The other advantage to the catback is mine came with dual 3in outlets, which look awesome.
Do the 80 series mufflers come with tips too? I believe its just the muffler.
Frozer!!!
Jan 19, 2024 04:55 PM
midias
Aug 22, 2015 01:42 AM
mustangman65_79
Aug 8, 2015 12:07 PM
gwade12
Aug 8, 2015 08:17 AM
Thaney9
Aug 7, 2015 08:25 PM
