tube on cats?
Old Sep 27, 2002 | 01:53 PM
19WS6T/A91's Avatar
tube on cats?
i am replacing the cats with pipes what do i need to do with the ends of these tubes?i believe that they are for the air but im not sure.
thanks
david
Old Sep 27, 2002 | 05:57 PM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
You can take off the entire AIR system which is what I did, or you can weld it into the exhuast pipe, or you can just let it hang there. All it does is push out air, so it won't hurt anything. If you get rid of the AIR setup, it'll free up quite a bit of space under the hood (you can actually see part of the engine then ) and it will make some maintenance easier.
Old Sep 27, 2002 | 06:55 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
My tube is welded shut. on the cat that is, before some perv says something.
Old Sep 29, 2002 | 04:45 PM
TPIGUY's Avatar
Mark
Hey mark is your car smog legal??
Thanks, TPIGUY
Old Sep 29, 2002 | 06:13 PM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
Now I get the whole remove the pipes and hoses part, but what do I do about the part that's connected to the serpentine system? Do I just leave it on and plug the last hose? Or do I take it off and run a smaller serpentine belt?
I plan on putting on headers with only the O2 bung, and get rid of all that A.I.R. crap, but I'm still a little confused as to what all should come off.
Old Sep 29, 2002 | 08:23 PM
kfoley's Avatar
Car: '85 Z28
Take the smog pump off and run a smaller belt. Someone around here has a pn for it. Mine is a V-belt so I just had to take it off.
FormulasOnly
Oct 2, 2015 05:52 PM
zman1969
Oct 1, 2015 11:09 AM
