Can I pass an emissions dyno sniffer with no cat?
Old Sep 13, 2000 | 04:37 PM
Superblue87Formula's Avatar
My cat is toast, I would like to put a test pipe in with the heat shield welded to it. My only problem is that I have to pass a dyno sniffer test and I'm not sure if it would??
1987 Formula 350, headman hedders, Accel supercoil, cap, rotor.
MAF screens removed. 160 degree stat and manual fan switch.
Best ET: 14.745@91.317mph-Stock
Best ET: 14.418@95.51 mph-Modded
Ridiculed Founder of the Traction Impaired Crew
Old Sep 13, 2000 | 06:30 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Your engine has to be really freakin' clean to pass with no cat, but it can be done.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Sep 13, 2000 | 08:47 PM
RS92's Avatar
I passed with a gutted cat and had lower numbers than with it. However,I did run a bottle of G2P in it before I went to get tested.
Old Sep 14, 2000 | 11:18 AM
G92Joe's Avatar
Forgive my ignorance, but I'm assuming "G2P"
is a Brand of dry gas??
Old Sep 14, 2000 | 01:28 PM
Kevin91Z's Avatar
Its a product called "Guarenteed 2 Pass", available at your local auto parts store.
Old Sep 15, 2000 | 08:00 PM
johns84bird's Avatar
Car: Pontiac Grand Prix GTP
Engine: 3.8L V6 SuperCharged
YES! you can pass with a gutted cat. I did, but lets just say I did a little tuning first! after I was done it was cleaner than with the cat on it. (i realize this is only because of the tuning and it is not always this clean). I will be buying a high flow cat when I replace my exhaust because i feel guilty about contributing to the pollution problem more than I should. by the way I didnt gut the cat, the previous owner did.
84 Firebird with Trans am ground effects- 350 4bbl GM crate motor (LM1), T-Tops, automatic, K&N filter, 180* thermostat, ram-air hood scoop, flowmaster muffler, Accel cap & rotor, MSD Super Conductor Wires. Coming soon: new interior (grey), rear end work, subframe connectors, polyurethane bushings
Old Sep 20, 2000 | 09:51 AM
ThrdGenRS's Avatar
I've been doing emission testing in Atlanta for about a year. It's rare but if your EGR system is working good...it could happen. But as for the test pipe...i don't know how they do it there, but here there is a visual cat test so you have to have a cat, gutted or not. Unless you are blocking off the EGR system completely, running w/o a cat will eventually cause EGR problems...so in my opinion I would say just bite the bullet and get a high-flo cat.
92firebirdguy
Sep 1, 2016 07:53 AM
86White_T/A305
Mar 6, 2016 01:48 PM
Johnny*G
Oct 20, 2015 12:37 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
89fast5oh
Sep 8, 2015 09:55 AM
