Which headers? 1 5/8, tri-y, 1 3/4 ???
Old Sep 19, 2000 | 01:36 PM
NOSFEDGTA's Avatar
I have a built 383 with NOS and was wondering if anyone has an Idea of what headers I should run. I was thinking of a set of Stans 1 5/8 Tri-y long tubes Or should I go with a set of 1 3/4 shorties, or should I get a set of 1 5/8 shorties? Thanx in advance.
Old Sep 19, 2000 | 01:39 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I'd go with 1 3/4" headers for your setup. Long tubes if you dont have to pass smog.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Sep 19, 2000 | 01:58 PM
Lostsol's Avatar
I agree, for the 383 I'd go with 1 3/4, I have a set of the Stan's 1/58 try-Y's on now, and also a set of SLP 1 3/4 that I'm changing to. The Stan's pipes are long tube and both tubes exit about four inches in front of the tranny X-Member, making exhaust routing more trouble than it's worth. I have dual exhaust, but no ground clearance because of where the pipes exit and how you have to run the exhaust. I suppose if you've got time and patience you could heat them up and bend them or something, but I'd say go with something else, and definatly bigger for the 383. Just my 2 cents.
Old Sep 21, 2000 | 02:02 PM
NOSFEDGTA's Avatar
Thanx for the help guys.
83RDRACR
Mar 26, 2016 08:13 PM
redformula88
Oct 14, 2015 06:08 PM
Chad Speier
Sep 24, 2015 12:32 PM
86White_T/A305
Sep 21, 2015 05:28 PM
hdis2002
Sep 8, 2015 02:52 PM
