I have a single 3" Flowmaster exhaust that rattles
Old Sep 21, 2000 | 08:37 PM
chevyii's Avatar
out the tailpipe. Yes, you can actually hear a rattle coming out of the tailpipe. I've replaced the muffler, changed headers, changed Y-pipe and checked for loose objects in the exhaust itself. I'm thinking this is a normal exhaust note for this configuration. I have a 406 and the noise is present between 1750 and 2000 RPM. Any suggestions would be appreciated.
Old Sep 21, 2000 | 08:46 PM
IROC-ZTWENTYGR8
Guest
Posts: n/a
Are u sure its the tailpipe?? When does it do it, all the time, or at idle............
Old Sep 21, 2000 | 09:00 PM
chevyii's Avatar
It does it around 1750-2000RPM in neutral of moving. It's worse under light to mid throttle. I can idle the motor up to 1800 and stand behind it while its rattling. If I hold a rag over the exhaust outlet it muffles the rattle but doesn't stop it. It sounds like something in the muffler is loose, but I've replaced it once. Maybe Flowmaster is prone to these types of problems.
Old Sep 22, 2000 | 05:38 PM
88irocz28's Avatar
Car: 1994 Trans Am
Engine: 5.7L LT1
Transmission: 6-speed
Look for loose hardware.
'88 IROC 305 TPI
Gutted airboxes
160 degree T-stat
Advanced base TPS voltage
Relocated IAT sensor
Momo steering wheel
Ram-air setup coming soon
Flowmaster muffler
Old Sep 23, 2000 | 11:34 AM
IROC-ZTWENTYGR8
Guest
Posts: n/a
I've never heard of a sound coming out of a tailpipe that u can baffle with a rag, but I do know that sometimes u can get a sound like u described that comes from the pipe that goes from the catalytic converter to the muffler. It can be too close to the brake line mount and rub up against it when the exhaust shakes the pipes. Check under your car and see if thats it, and if it is, go to my post: Is there something I can do to make this stop these sounds??It sounds like u have the same thing I do.
[This message has been edited by IROC-ZTWENTYGR8 (edited September 23, 2000).]
Old Sep 23, 2000 | 11:35 AM
IROC-ZTWENTYGR8
Guest
Posts: n/a
Double Post
Hotrodboba400
Dec 10, 2019 07:07 PM
customblackbird
Oct 1, 2015 04:30 PM
ericjon262
Sep 11, 2015 06:07 PM
89fast5oh
Sep 8, 2015 09:55 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
