Taking off cat..
Old Sep 19, 2000 | 01:28 AM
gsmann's Avatar
Taking off cat..
I have an 1986 Transam. Just finished putting in a 350 with melling cam. I want to take off the cat since I'm getting a custom chip from TPIS. When I cut out the cat, what do i do with the air tube goes into it?
Please Help. Thanks.
Gary Mann
1986 Recaro TransAM
350 TPI w/ melling cam
TPIS adjustable fuel regulator
Bosch injectors
K&N element
3 inch Flowmaster
160# Thermostat
Modified MAF
Old Sep 19, 2000 | 01:39 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
You can remove the air tube as well. Either remove it, or cut it off.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Sep 19, 2000 | 02:58 PM
gsmann's Avatar
Do I plug the air tube when i cut it off or just let it flow?
gary mann
Old Sep 19, 2000 | 10:51 PM
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
ehh just cut it or get rid of the air crap al together....
Steve
86 Firebird, LG4, t-tops, 2.73 open rear, SLP 3 inch cat back exhaust, catco cat, Coming mods: Edlebrock 1 5/8's Headers, 2 inch cowl hood with custon alumin cold air box, 3.42 posi disc rear, T56, and hopefully a new set of heads and a nice CAM!
My Webpage- Battle of the birds, My own Thirdgen Page, still under construction, http://www.geocities.com/soares711/index.htm
88 Firebird Formula- deseased 2/9/99- 305 TPI, SLP 3 inch exhaust, SLP Intake runners, SLP cam, 3.45 BW disc brake posi, WS6, NOS, and all that good stuff, 13.8 on the motor, 12.89 on NOS and slicks! Hit by what else!?!? a FORD EXPLORER!!!!!!
Old Sep 24, 2000 | 08:48 AM
Stell1579's Avatar
i would unbolt it from the source (believe the smog pump or a spliitter a little further upstream. then could always remove the injection tubes, smogpump and the rest since there is no cat anyway. will probably cleanup the engine compartment a lil better too
-Stell
1988 IROC 305TPI MINT!!
Mods= Accell SuperCoil, MSD 6A, Ported Plenum, No MAF Screans , K & N, 160 Thermostat+ Temp Switch
And Always Trying To Go Faster
Hotrodboba400
Dec 10, 2019 07:07 PM
customblackbird
Oct 1, 2015 04:30 PM
Metalizer
Sep 13, 2015 12:56 PM
Fox118
Sep 12, 2015 09:29 PM
formula1LE
Sep 12, 2015 08:31 PM
