Loctite on header bolts
Car: it doesnt really drive right now
Engine: 383
Quick question. SLPs install kit didnt include lock washers. Should I loctite the header bolts?
SB
SB
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Originally posted by Momar
I would buy a set of stage 8 locking header bolts. They are awsome.
Ben
Ben
Much easier than trying to get a socket on there. AJ
Car: '85 Z28
Transmission: WC T5, 3.23 posi
The Stage 8 bolts are definitely worth it. You could probably use loctite, but I'm not sure if it would stay. Of course it could stay very well and you have a very difficult time getting the bolts off.
Transmission: 4L80E/4L80E
Forget the Locktite. It won't handle the heat.
The best-holding Locktite can't be loosened with hand tools, but can be with the addition of - you guessed it - heat.
tom1985
Apr 19, 2016 07:55 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
hectre13
Sep 8, 2015 03:38 PM
Dialed_In
Aug 20, 2015 01:45 PM
