will hooker long tube headers with 5sp and use stock exhaust
i need to know if it is possible to have long tube with a 5 speed and use the single exhaust from the cat back
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Long tube headers in a third gen are not designed for street use. A custom exhaust will need to be fabricated. Ground clearance becomes a problem on some cars.
Stephen's racing page
87 IROC-Z Pro ET Bracket Race Car and knocking on the SuperPro ET class
383 stroker (carbed) with double hump cast iron heads and pump gas
LS6 Big Block buildup now in progress
Best results before the engine blew up
Best ET on a time slip: 11.857
Best corrected ET: 11.163
Best MPH on a time slip: 117.87
Best corrected MPH: 126.10
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
Best 60 foot: 1.662
I've installed Hooker LT's on a 4th gen before. You WILL have to make a trip to the local muffler shop after you're done. They had to make a totally custom Y-pipe for it. IRS sells a Y-pipe for 4th gen, but it still didn't work.
HTH!
AKA Pony Punisher II on all other boards.
89' Iroc-Z
ZZ3 short block-355 TPI ZZ9 cam
NOS 150 shot.
blah...blah...blah..
95' T-56, 6-speed
99' Z' rearend w/ 4.10's
1997 black Trans AM
A4, bone stock except for the Flowmaster.
HTH!
89' Iroc-Z
NOS 150 shot.
95' T-56, 6-speed
1997 black Trans AM
1992 Trans Am
May 10, 2023 07:19 PM
