A.I.R. system removel
Car: 1987 Formula 350
Engine: 6.0 boost and smak
Transmission: 4l80e
Axle/Gears: 9bolt 3.27
i need to know if anyone knows if there is any draw back to the removel of the A.I.R. system on a 87 formula 350 besides emissions bullcrap. thanks John
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Nope. None. Some say that if your remove the AIR pump and then reroute the belt that you could 'throw the belt' (i.e. serpentine belt gets thrown off the pullies). But, I rev my car to 6500 rpms (and sometimes more by accident) and everything is great.
TRAXION's 1990 IROC-Z
Best Time = 12.587 @ 107.97mph (1.710 60ftr) on the long runner setup.
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels. Stock Wheels. No Weight Reduction.
Gunning for NA 11's with the MiniRam II and Hooker LT Headers.
-=ICON Motorsports=-
Moderator: PROM board at thirdgen.org
Transmission: 4l80e
Thanks guys, i will be making a lot more messages here for helpfulness in my ignorance. I'm sure I will be of help to you in the future,and will be glad to help. Oh! My formula 350 thanks you for the reduction of parasitic drag!!!!!
Car: 92RS
Engine: LS 402 inwork
Transmission: TH350
Axle/Gears: 10 bolt,3:73's
I twist my motor to 6500 also with the AIR pump removed and have yet to throw the belt. I'd love to see this belt get thrown!!! Hey Sean how did you get rid of both pulleys on the same side and still get it to work?? The only answer is if your A/C pulley was on the drivers side to begin with.
White 92 RS,388 cu.in.N/A
3.73 gears,auburn posi
Best 60 ft : 1.97
Best 1/4 : 12.679
all runs made on BFG Radials (NOT DRAG)
Complete Steve Spohn Rear Suspension
Full Custom Dash full of Autometer guages
Extremely Loud Stereo !
Driven Daily
Best 60 ft : 1.97
Best 1/4 : 12.679
Driven Daily
Yep.. I got my car with the AIR pump removed already.. I want to take the compressor out, but I'm not sure of the new routing.. I guess i could in theory go OVER the tensioner (making it useless..and not tensioning...) but i don't like that idea.. and I'm not quite willing to pay like 50$ for a stupidass pulley..
I've been toying with the idea of using a lawnmower wheel as a pulley... hehehehe I think if i get one with the right width, and I mount it up real nice, it would work... Worth toying with the idea, at least..
91 T/A 305
STB, Airfoil, Hooker cat-back, pseudo-cold air to K&N, Accel coil, !cat, !smog pump.
300 lb*ft of rice churning power.
91 T/A 305
I forgot to add.. I used a 785K6 belt, and yes it goes OVER the tensioner. The only problem I can see is that BIG empty spot where the a/c USED be housed. As to removal of the AIR system, it just unscrews from the exhaust manifold, a 9/16 wrench I think should do it, along with a generous amount of mystery oil, or liquid wrench.. I sent slush the pic of the belt routing.
Theres a tech article on the thidgen home page in the tech article section that fully explains how to totally bypass the AIR pump. It also clearly shows the new belt routing.
Tim
Tim
[Sold] Flowmaster exhaust system
Night rider327
Oct 9, 2015 09:25 AM
Night rider327
Sep 25, 2015 04:47 AM
It's PFM..
