header install
Old Oct 16, 2002 | 06:23 PM
IROCZ88x's Avatar
Car: 1988 IROC-Z
Engine: LB9
header install
i know this has probably been asked before but i gotta ask again, u guys are always helpful...im ready for headers...its the next step...i love working on my car but i have little to no experience. Is it difficult to do...i need the engine to stay in the car...i guess it involves removing a few items from the passenger side but anyone with time wanna quickly give me an apporximate run through to see if im capable...i want edelbrock or hooker unless anyone suggests otherwise (im not made of money) aight cool, thanks a lot
Old Oct 16, 2002 | 06:37 PM
FruityOne's Avatar
Car: 1989 TransAm GTA
Engine: One sweet modified 355 TPI.
Transmission: The kind that shifts....
Removing all that stuff was...errr...........fun? At least for me removing the A/C stuff was easy. Well, we used a gauge to check the pressure of the A/C system and it came up nil, nadda, zip, zero.
I had to take the engine down to the short block though.
Old Oct 16, 2002 | 06:40 PM
MikeS's Avatar
Ok, here is the list of what I had to remove this weekend:
Passenger side:
Remove AIR tubes and hoses
Remove AIR pump
Loosen alternator to move it aside
Remove spark plugs
Remove fan switch
Remove manifold
Install header
Reinstall plugs, fan switch
Reinstall AIR (if required)
Retighten alternator belt
Driver side:
Remove A/C compressor and set aside
Loosen PS pump bracket/brace
Unbolt fuel line mount to A/C bracket
Remove compressor brackets
Unplug knock sensor, O2 sensor, etc.
Remove spark plugs
Remove manifold
Install header
Reinstall sensors
Reinstall AIR (if applicable)
Reinstall fuel line mount
Reinstall compressor bracket/brace
Tighten all brackets back up
Reinstall plugs
Reinstall A/C compressor
That's about it. Not really all that much stuff, but it was time consuming. This was on an 87 305 TPI car, by the way. I also did some other things (rearrange brake lines, wires, etc to keep away from heat), but there isn't all that much that really has to move. Hope this helps.
Good luck,
MikeS
Old Oct 16, 2002 | 06:47 PM
IROCZ88x's Avatar
Car: 1988 IROC-Z
Engine: LB9
it does help a lot, ur "engine accessories" are on different sides in some cases in 87 but thanks a lot, i want to do it myself!!..i get excited...:lala:
Old Oct 16, 2002 | 06:56 PM
MikeS's Avatar
It is a big project if you are just getting started. Make sure you have plenty of time to get it done. I waited until I had a long weekend in case anything went wrong. And it helps to have all kinds of tools. Sockets, wrenches, extensions, wobble extensions, u-joints, even crowfeet...
Old Oct 16, 2002 | 07:25 PM
88GTAinRI's Avatar
From: Ocean State, lil Rhody, the biggest littlest state in the union, Rhode Island
Car: 1988 GTA Black/Gray
Engine: Blown 355
I've done headers twice on thirds gens and both times the engines where out of the car. The part I could see as being a real bitch, in the car, is the damn heatshields on the stock manifolds and those stupid metal tabs they bend over the bolts to keep them from loosening. I have SLP headers on my recent car and I don't like them as much as the Edelbrocks I've had in the past. The Edelbrocks had more clearance between the engine. I've already burnt a damn spark plug wire and the car was only fired up for 20minutes. Just my 2 cents.
sweet_87_iroc
Sep 25, 2015 10:01 PM
Wesly_66
Aug 26, 2015 09:55 PM
mdtoren
Aug 23, 2015 12:52 PM
theurge
Aug 21, 2015 12:46 PM
drathaar907
Aug 6, 2015 04:20 PM
