what's the best headers for a 383??
Old Oct 14, 2002 | 02:55 PM
92TPIZ28's Avatar
Car: 1992 Camaro Z28
Engine: 355
Transmission: T-5 w/centerforce dual friction plate clutch
i'm about to swap my 305 with a 383 and i'm not sure which headers are the best. i'm leaning toward the SLP's, but which size would be better, i would think the 1 3/4 but i'm not sure and are the A.I.R. tubes neccessary if i don't care about emissions? thanks.
Old Oct 14, 2002 | 03:09 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Get some 1 3/4 Hooker headers. I wouldn't get the AIR tubes if you don't need emissions. They just get in the way.
Old Oct 14, 2002 | 05:16 PM
Blackroc86's Avatar
Car: 1986 Iroc
Engine: 454 Demon 850DP
Transmission: TH350, 3500 stall
I would go with the Hooker Super Competition long tubes, part number 2210. I am going to get them for my 406 as soon as I have the money.
Old Oct 14, 2002 | 06:16 PM
92TPIZ28's Avatar
Engine: 355
do the hooker headers come with a y pipe for dual cats?? and i thought slps were the best or am i mistaken. thanks for your guys help
Old Oct 14, 2002 | 11:59 PM
badgta's Avatar
Car: 1991 FORMULA
Engine: ZZ4 + LT4 HT CAM 430HP
Transmission: 700-R4 COMING T56
Axle/Gears: 9" 4.56's (COMING)
nope
slp headers are the best for emissions compliant car only........
theres no way imho that they are better than 1 3/4 long tubes flowing through a dual exhaust.............
if emissons or ground clearence is a concern, slp's are good....
if emissions are out the window, and all out hp is key, go with some sort of full length header like hooker and hedman.....
p.s. hedman sells a long tube header for our cars for 104$ through jegs......
p.p.s heres a pic of the hedmans
Old Oct 15, 2002 | 07:02 AM
Blackroc86's Avatar
Car: 1986 Iroc
The thread starter mentioned he was not concerned about emissions. Also he said he needed 1 3/4 primaries. Do the Hedman long tubes have 1 3/4's as any info I find on them say they are 1 5/8.
Old Oct 15, 2002 | 10:11 AM
badgta's Avatar
Car: 1991 FORMULA
yea
their 15/8 primarys........ i din't think a motor will suffer too much with that size of primary........
it what i'm going to run on my 500hp 383, w n2o
Old Oct 15, 2002 | 10:47 AM
Blackroc86's Avatar
Car: 1986 Iroc
I guess it depends on the exhaust ports on his heads. If he has large D shaped ports like my fastburns then you pretty much need the 1 3/4 primaries to get a gasket to somewhat match the ports.
Old Oct 15, 2002 | 11:02 AM
92TPIZ28's Avatar
Engine: 355
will the hedmens work for dual cats?
Old Oct 15, 2002 | 09:16 PM
badgta's Avatar
Car: 1991 FORMULA
nope
hedmans are made for a do it yourself custom exhaust.......
if you need somthing that will bolt up to the existing exhaust try slp's....
they sell a header i think 30014 for dual cat's w/o air, for like 3 somthing......
i have afr 190's with d exhaust prots, and like the feller said above, they dont match up to well to the exhaust port.......
but reguardless, if ya need a dual exhaust that kicks ***, then hedman and hooker rules......
Old Oct 16, 2002 | 11:02 AM
Momar's Avatar
Be warned that the headman lt headers wont hang down low enough to run the pipe back past the subframe. You will have to use or make some kind of bend to clear them. That is part of the reason I went with the hookers.
Ben
P.S. What the heck is up with a p.p.s.? I think thats a little excessive don't you? j/k
Old Oct 16, 2002 | 01:10 PM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Nothing can touch the Hooker SuperComp Long Tubes (PN 2210) in terms of flow (cept for maybe the Hedman Huslers but that is a different story entirely). You'll need a custom Y-pipe or one from Mufflex (PN TPI-Y
http://www.celligent.com/tim/iroc/LT_install/
Tim
Old Oct 16, 2002 | 01:32 PM
Momar's Avatar
Traxion, have you got that exhaust finnished yet? Should be sweet.
Old Oct 16, 2002 | 11:21 PM
badgta's Avatar
Car: 1991 FORMULA
ahhhhh
Ben
i got the universal s extensions from hedman to clear that.... fastthirdgen has the setup i'm going to go with......
Old Oct 16, 2002 | 11:55 PM
Berlinetta's Avatar
What kind of ground clearance issues are there with the Hooker long tube headers? How does the y-pipe setup look on something like that?
Old Oct 17, 2002 | 07:15 AM
Momar's Avatar
There is only 1 y pipe made for it that I know of. It is made by mufflex. Here is a link to a guy that has it. http://www.geocities.com/cfrios/PhilsIroc.html
83RDRACR
Mar 26, 2016 08:13 PM
Chad Speier
Sep 24, 2015 12:32 PM
hdis2002
Sep 8, 2015 02:52 PM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
