HOOKER CAT-BACK?
Old Oct 3, 2000 | 07:48 AM
PAformula's Avatar
HOOKER CAT-BACK?
Has anyone installed a Hooker cat-back system? How does it sound? I want a good cat-back for around $250. Any recommendations?
BLACK 1989 FIREBIRD FORMULA 350
K&N, ACCEL CAP & ROTOR
Old Oct 3, 2000 | 03:45 PM
Dan87IROC-Z's Avatar
The Hooker system sounds great, I love mine. Its very easy to install too, only took me like an hour or so. The one problem is that the intermediate pipe sits on the rear suspension unless you buy a U clamp and put it through the hanger.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission with 2.77:1 Rear End
Current Mods: Edelbrock TES 1 5/8" Headers, Hooker Aerochamber Cat-Back System, Performance Resource Chip with 160* Thermostat, Accel Ignition Components, K&N Filters, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET : 14.3 @ 97mph
(corrected for elevation)
Old Oct 3, 2000 | 06:17 PM
88'camaro305TBI's Avatar
Car: 88 IROC
Transmission: auto
I also have the hooker aerochamber catback which i installed myself. It took me way longer than an hour to install though (I spent most of the time cutting out my old exhaust system with a dremel.)
Mods:Hooker Aerochamber 3" exhaust, gutted kitty,
March 2 piece underdrive pullies, smog pump gone,;these two made a very noticable difference.
14x4 K&N open air element filter-the best mod so far
Eibach springs with KYB's all around.
Appearance: Harwood cowl hood, Z-28 wing, painted black(7/20/00)-original color was light blue
*All these mods were made this year
Stock Options:117,000 miles on motor, 5spd, TBI, 305, T-tops
Run a best of 16.7 @85mph with traction problem. Have to try again sometime.
Old Oct 3, 2000 | 07:38 PM
MrJ's Avatar
MrJ
You cut off your old exhaust pipes with a Dremel? I'm curious, how exactly did you do this? Which attachment did you use on the Dremel? How long did it take you? thanx
91 Trans Am WS6
5.0 TPI auto
Flowmaster 3" 2 chamber catback
Trans Go shiftkit
2000 stall converter
supposed 'peanut cammed' car (yeah, right)
MoreMoodThatMod
Old Oct 13, 2000 | 01:48 AM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
Transmission: Pro-Built 700R4 2400 ACT Stall
Axle/Gears: 2.77 Borg Warner 9-Bolt
Heh, i've done the same, my dremel tool came with little circular flat cutting disc's (easy to break), cuts right through though...
89 IROC-Z 350 TPI
-Flowmaster Catback
-Performance Resource Chip
-700R4 (Rebuilt) Too much done to actually list
-K&N Airfilters
-Ported Plenum
-2.77 Gears (not much to brag about but eh, its there)
-Future:
-383 Stroker?
Old Oct 13, 2000 | 01:50 AM
BOWTIROC's Avatar
From: Coulterville, IL...Currently on Beale AFB, CA
Hooker was the best cat-back I have had...and I have had quite a few
Old Oct 13, 2000 | 10:36 PM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
I like it a lot. I have sound clips on my website if you are interested.
http://www.isthq.com/~dan/fcar.html
Daniel Burk
'84 Trans Am WS6/L69
KB SFC, Moser axles, Torsen Diff. PST suspension, Braided stainless brake lines, Koni struts, 11-inch rear disks,Spohn Adj. torque arm,
Ported 305 heads w/1.94"intake valves, Comp Cams XE262H, Griffen alum. radiator,
Turbine Technologies 2500 stall converter, underdrive pulleys, Crane Hi-6 & more.
1.05g skidpad verified.
New best E/T! 14.039 at 100.82 MPH in 41 degree air at Stanton, Michigan.
no green
Jan 9, 2016 09:22 PM
thekurlyone
Sep 30, 2015 12:54 PM
Chevykid810
Sep 28, 2015 12:57 PM
ssgt usaf
Sep 21, 2015 12:45 PM
Tylermcclinton
Sep 17, 2015 07:50 PM
