Air tubes... help
Old Oct 13, 2000 | 02:35 AM
Ehelmsin's Avatar
Air tubes... help
I was considering capping my AIR tube ports on my manifolds, pulling my smog pump, and capping the line from the cat. I dont have emmissions where I live so no worry there. What I was wondering is will this cause any SES lights from my computer, like an EGR error? I would like to know before I do it, any other help on this subject would be a help. Thanks in advance!
Old Oct 13, 2000 | 07:59 PM
IRACE87's Avatar
Car: 1987 IROC-Z
Engine: 383 HSR, AFR 190
I did remove my smog pump ,air tubes,gutted the cat and removed the smog pump solenoid (the black thing on the passenger side)and didn't have any problem so far with the ECM.
1987 IROC w/T56 and a 383 TPI in the works
Old Oct 14, 2000 | 05:57 AM
SeanSullivan's Avatar
The only code you might get is a 32, EGR, in normal cruise speeds 65 to 75. I used 1/4 npt pipe plugs in the holes where the AIR tubes went into the exhaust manifold, when I removed it from my car.
Old Oct 14, 2000 | 03:23 PM
Ehelmsin's Avatar
thanks SeanSullivan, do you have any more details on those AIR hole plugs, length, thread, material? I want to go ahead and get them before I start pulling stuff apart.
Old Oct 15, 2000 | 02:10 AM
Iroc_Z28's Avatar
you should be able to get those plugs at in local autoparts place just get 1/4inch pipe plugs ....i removed all the smog stuff from mine including the cat convertor and i havent had any trouble with it ...when i done mine i got the plugs from advanced auto hope this helps
Bubbajones_ya
Jul 6, 2024 08:32 PM
db057
Apr 28, 2019 07:45 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
edoff13
Sep 11, 2015 03:55 AM
scotrans am
Sep 5, 2015 04:26 AM
