SLP header owners?
Old Oct 9, 2000 | 04:13 PM
kjgroen's Avatar
Car: Trans Am
Engine: L69
SLP header owners?
I have a stock 1984 L69 trans am I am going to get the headers from SLP. Do I need to get the catalyst adapter and the istallation kit also? Thank you Kevin
Old Oct 9, 2000 | 05:22 PM
Dan87IROC-Z's Avatar
I think that you will need it. The kit includes all sorts of requiered parts. I would call SLP and ask them to be sure though
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission with 2.77:1 Rear End
Current Mods: Edelbrock TES 1 5/8" Headers, Hooker Aerochamber Cat-Back System, Performance Resource Chip with 160* Thermostat, Accel Ignition Components, K&N Filters, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET : 14.3 @ 97mph
(corrected for elevation)
Old Oct 9, 2000 | 05:39 PM
gearrrhead's Avatar
Car: 1990 iroc
Engine: 350 tpi
you will need something. the y pipe has no flange. if you have a cat on your car you will need something to hook to it.
"I don't trust anything that bleads for five day's and doesn't die"
88 iroc slp headers,borla catback,procharger to come soon.
Old Oct 9, 2000 | 06:51 PM
IRACE87's Avatar
Car: 1987 IROC-Z
Engine: 383 HSR, AFR 190
There installation kit is expensive you will save some money if you buy everything you need at your hardware store or speed shop .And to hook the Y pipe to your cat you will have to buy there adapter ,single cat adapter part no is 30038 ( 3 inches in diameter ).
1987 IROC w/T56 and a 383 TPI in the works
Old Oct 18, 2000 | 11:56 PM
98camaross's Avatar
WHAT IF YOU HAVE A DUEL CAT ????
Old Oct 19, 2000 | 06:54 PM
CanadianBeast's Avatar
I bought mine used without the AIR provisions and was wondering if anyone knew if the stock manifold bolts will work or if I need to go get new ones, and what length I will need.
Also when GMHIGHTECH magazine put them in magnum TPI they said a three wire O2 sensor is needed and angled plug boots.
89 Iroc-Z
L98, cat_back, no cat, K&N, 3.42 gears, airfoil, shift kit, accel everything, B&M megashifter, useless JET II chip
Coming SLP headers, pulleys, afpr, drag radials
Hotrodboba400
Dec 10, 2019 07:07 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
89fast5oh
Sep 8, 2015 09:55 AM
84 TA NV
Sep 6, 2015 08:02 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
