BHP increase without CAT?
Old Oct 26, 2000 | 02:56 PM
SIMON HOLTBY's Avatar
Guys,
Here in the UK a cat is not required by law on my car. The only requirement is that the CO is below 4.5%. When I come to change the exhaust is it worth removing it? What sort of BHP increase would it produce? Is it easy to gut a cat or should I just make a new bit of pipe up instead?
Simon Holtby
'88 Camaro 5.7 TPI
Old Oct 26, 2000 | 04:56 PM
Ehelmsin's Avatar
I was reading an artical the other day (In car Craft I think) that was testing cats. They did gain HP by removing the cat, but lost torque. But the total change was only 2-3 either way.
Old Oct 29, 2000 | 10:26 AM
If it doesn't give more than 30 bhp I think I'll do my bit for the environment and leave it on!
Regards
Simon Holtby
88' Camaro 5.7 TPI
Old Oct 31, 2000 | 11:56 PM
Zar's Avatar
Zar
If your worried about pressure then leave the cat on and not use a muffler.
Old Nov 1, 2000 | 09:21 AM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
I've removed my cat and I've definitely noticed improved performance and better sound.
Mongoose-NCTGA-1990 Pontiac Formula/305 TBI-700R4 with Edelbrock Performer TBI intake,TES headers,and STB,K&N,MSD-6AL,Holley laser shot coil,Accel Extreme 9000 wires,Jet Stage 2 chip,TCI shift kit with corvette servo,Richmond 3.73 gear with Auburn 3 series posi,no cat,SLP 3" cat back,Eibach sportline springs,Energy Suspension poly throughout,Lakewood LCA and adjustable panhard bar package,SSM subframe connectors,IROC wonder bar,Tokico 5 way adjustable struts and shocks,Autometer electric fuel pressure gauge,Alpine,JL Audio,MB Quart,92 GTA taillights,92 GTA aero wing and hatch,Steve Spohn LCA relocater kit,MacEwen White face gauges,84 T/A cold air induction air cleaner.
Old Nov 9, 2000 | 09:45 AM
jrr's Avatar
jrr
If you remove the cat and end up with CO levels above 4.5%, try this. Overdrive the AIR pump! Get a pulley about half the size of the original and put it on before you go to the inspection station. That overdriven air pump will flush so much fresh air into the exhaust that it ought to help you pass your emissions test. Now, how much power will be lost I haven't any idea. But it's easier to change pulleys than to change out cat converters.
LT1Formula
Oct 8, 2015 08:34 PM
gord327
Oct 3, 2015 01:25 PM
