Removed Pollution Pump and lines
Old Nov 13, 2000 | 01:37 PM
Steve89GTA's Avatar
I removed the lines to the exhaust manifold and plugged them up with some brass fittings. I also plugged the line coming form the high-flow dynomax cat. I'm hearing now that this will harm (melt?) my cat. True??? Since I still have the pump on the car and it is blowing air, should I connect the air coming from the pump directly to the pipe coming from the cat???
89 GTA
305 TPI
WC 5spd w/3.45 rear
Accel Cap & 8mm Taylor's
MSD6A Ignition
Accel Supercoil
Custom Cold Air Induction
Jet Airfoil
K&N Airfilter
160 deg stat/fan switch
Hypertech Thermomaster Chip
Steel Rad
Cat back 3" Exhaust
HiGh FlOw Dynomax Cat
Old Nov 13, 2000 | 07:53 PM
bad camaro RS's Avatar
naw had my cat on car for over a year with air pump and all removed no harm but did drop .3 in a quarter after taking cat all the way off
1992 camaro RS
373 10 bolt rearend
ssm sfc's
87 350 TPI
bored 30 over
compucam 2032 with 1.6
482-495 LIFT 214-220 duration full roller rockers
msd6AL
1 5/8 headman headers
2 `1/2 flowmaster exuast
k&n filters gutter air box gutted maf
3 pc under drive pulleys
no emissions no egr etc
custom ED Wright chip
eddelbroc intake base and runners ported plenum
midly ported and polished stock heads
Taylor 8mm wires
B&M mega shifter
gutted maf/airbox
hotchkis lower control arms
3" exhuast cutout
homemade cold air intake
2000 tci stall
700R4 with B&M shift kit
new best ET 13.5 @104.66
Frozer!!!
Jan 19, 2024 04:55 PM
backtothe80s
Sep 5, 2015 12:39 AM
AkDrifted
Aug 17, 2015 07:45 PM
Kaweh
Aug 9, 2015 02:54 PM
3rdgenparts
Aug 8, 2015 07:09 PM
