Plugging up the air tubes...
Old Oct 30, 2002 | 12:25 PM
KlayBuRn's Avatar
Want to take my emissions **** off, i know this gets brought up a lot, and i tried to search, but i cant seem to find the exact size of the thread i would need to plug up the holes? im assuming its just a drop something in there and screw it in, or am i wrong? im going into this blindly, so anything would be appreciated...
:hail:
Old Oct 30, 2002 | 02:14 PM
turtle's Avatar
1/4 in. npt pipe plugs i know they sell them at advance just bought some about a week ago. they worked great for plugging the air tubes so you know, screw in, done.
Old Oct 30, 2002 | 03:37 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
THEY ARE NOT NPT!!!!!!!
I keep trying to overcome this false information and it just isn't working.
They're flare plugs made for 1/4" tubing. When you pull out the tubes you'll see that they are flare fittings in the ex. manifolds. Therefore you want to get FLARE PLUGS!!!
BTW, that's not directed right at you turtle. It's just that I used that same info to go buy mine, got home and they didn't work. So I went to a NAPA parts store and they showed me that I needed flare plugs, not pipe plugs. No flame meant, OK?
AJ
Old Oct 30, 2002 | 05:07 PM
turtle's Avatar
let me double check i have 1 in the box still in the bag. dang have the plug not the bag it came in. but mine is definately not flared.
did you pull the arestor or did you plug the arestor? i plugged the arestor so 1/4 npt worked great. you could also pull the arestor and put a cap on the line that works to and looks allot cleaner.
you lost me on the flare, is it still 1/4 in? oh i think i got it yours is a rubber plug yes? press in, i used a hex head npt screw in worked great.
Old Oct 30, 2002 | 06:45 PM
KlayBuRn's Avatar
lol
so which is it ?
Old Oct 30, 2002 | 07:31 PM
turtle's Avatar
well if you can find a 1/4 in rubber plug that would work but if you can find a 1/4 in hex head plug that works too. I'm still not crystal on what AJ was talking about. but i bought the hex heads at advance like a week ago and they worked fine as long as you leave the arestor on the air tubes.
Old Oct 30, 2002 | 08:41 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
rubber wont work. headers w/o air tubes thats the perfect solution. i would get either, there might be a "better" one but it doesnt matter IIRC
Old Oct 31, 2002 | 08:24 AM
AJ_92RS's Avatar
turtle......Dude!!!!!!!! WTF are you talking about?
WTF is an arestor? Is that what you call a cop?
OK. KlayBuRn,
You want to know what to use to plug the holes in the exhaust manifolds where the AIR tubes are right now, correct?
Answer that first that way we can make sure that we're all on the same page.
AJ
Old Oct 31, 2002 | 10:08 AM
turtle's Avatar
put the tools down and back away, now!!! hahaha
no arestor or silencers. black bit on the end of the air tube i have always called them an arestor.
headers without air tubes is much better, but a heat resistant plug does work. tried it worked fine, but the hex head npt's worked better.
Old Oct 31, 2002 | 02:44 PM
AJ_92RS's Avatar
turtle.....
Do you know what a flare fitting is?
The fittings I used on mine were flare plugs that look just like a flare fitting, but plugged. And yes, they are a hex head.
The stock tubing that goes from the diverter to the exhaust manifolds have flare fittings on the ends. They have a 45* (or 30*) flare on the end of the tubes. Then the flare fitting is beveled inside to clamp the tube onto the flared opening inside the hole of the exhaust manifolds. (see attachement)
For example, the flex hose you have on your dryer in your house has flare fittings (if it's gas). You cannot use NPT fittings and have it seal properly. The reasons are they are two totally different sizes, they have different thread pitch, and obviously one has a flare and the other doesn't.
You may have gotten the NPT plugs in your exhaust manifolds, and they may be holding for now, but eventually they will leak and they may back out.
AJ
Old Oct 31, 2002 | 05:54 PM
turtle's Avatar
now i see where the brain fart is. i'm not removing the air tubes from the manifold. i am leaving them there and capping off the end of the air tube where the arestor is.
So are meaning with the tubes off or still there but capped?
Old Oct 31, 2002 | 06:09 PM
KlayBuRn's Avatar
I want to remove all emissions items, and plug the holes in the manifolds...
and yes, i will be getting headers without the air tubes, but this is something that i would like to do, to just get emissions off for now, since parts should be cheap
Old Oct 31, 2002 | 11:28 PM
AJ_92RS's Avatar
That's what I figured. There was some mis-communication somewhere.
No harm no foul.
AJ
Old Nov 1, 2002 | 06:43 AM
turtle's Avatar
K I'm shutting my pie hole now.:hail:
Old Nov 1, 2002 | 05:53 PM
KlayBuRn's Avatar
So what do i use?
Old Nov 1, 2002 | 06:39 PM
turtle's Avatar
listen to AJ! I'm a tard if i paid a little more attention?
Old Nov 2, 2002 | 11:45 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
I used 1/4 pipe plugs (slight flare) that I got from the NAPA machine shop. Worked and are still working great.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
LittleFranks
Sep 17, 2015 12:22 PM
BurlyChev
Aug 22, 2015 01:52 PM
