baking header paint??
Old Sep 26, 2000 | 09:05 PM
Val's Avatar
Val
How should I bake the header paint onto full length headers?? I don't really want to spend the $$ for coating, so my plan is to paint them then wrap with header wrap.
Would letting the paint cure with header wrap around it affect the paint in any way?? Anyone have a really big oven??
1988 Formula L98
1988 IROC-Z supercharged
http://www.shsu.edu/~stdvjs11
Old Sep 26, 2000 | 09:07 PM
Jester's Avatar
know anyone with a bar-b-que?
Old Nov 28, 2000 | 04:20 PM
Chevychad's Avatar
Are these headers going on the IROC, or are you replacing the ones on the Formula?
Chad
Supercharged '88 IROC
**SOLD**
Old Nov 29, 2000 | 12:07 AM
88IROCs's Avatar
<a href="http://www.techlinecoatings.com/">Techline Coatings</a> offers coatings that you can apply yourself, which do nor require baking. They also offer coatings that require heat curing if you find an oven. All of thier coatings are water-based, so they will not produce toxic fumes. Check with your local auto parts stores to see if Techline's coatings are carried, or order them from Summit or Jeg's.
Personally, I have plans to coat my entire exhaust(inside and out) in a few weeks, when I pull the engine. I also plan to use a variety of thier coatings on the intake(plenum, runners and manifold) to keep those parts cool. Then I'll coat all visible parts with "CermaKrome" to improve the looks.
He who hesitates,... is lost!
Old Nov 29, 2000 | 06:49 AM
ERIC'86IROC's Avatar
I used the high temperature header coating from The Eastwood Company and I'm very pleased. It produces fumes for about a minute. Painting the headers will not compare to using this coating. Very easy to apply and one can will coat shorties headers at least 6 or 7 times. The only down fall is if you want to touch them up later the shelf life once opened is only six months and one year before opening. They have dark grey cast iron color and a bright aluminum color. I used the darker one. They still look good and it has been six months. My headers were a year old and rusty, then sandblasted before I coated them. Check out there website.
350 Vortec, forged flat-tops, CompCams XE268, Edlebrock RPM, Holley 3310, TH350 w/Holeshot 2400, 3.23 posi, Heddman shorties, HEI
Street Lethal
Apr 30, 2019 12:14 PM
92projectcamaro
Jan 18, 2016 08:00 AM
Dyno Don
17
Nov 2, 2015 11:43 PM
Reddeath210
Oct 6, 2015 08:20 AM
hectre13
Sep 8, 2015 03:38 PM
