Hooker Long tube headers?????????
Old Nov 15, 2000 | 11:19 PM
Iroc_Z28's Avatar
Is anyone running hooker comp headers long tubes on a 350 and if so are they a good set of headers...and has anyone had any problem with them
Old Nov 16, 2000 | 05:25 PM
Hurtin4Hp's Avatar
Car: Transformed 86 Coupe
Engine: 400 sbc
I'm running the long tube super comps on a 400 and I really like them. The #7 spark plug was very close to the tube so I had to clearance it a little. I have no ground clearance problems though.
Old Nov 19, 2000 | 10:48 AM
96BlownSSragtop's Avatar
Car: 89 Formula
Engine: Nada - v4.0
Transmission: Nada - v3.0
Axle/Gears: Nada - v3.0
hey Hurtin...
Is your car stock height or lowered?
Chris
Old Nov 27, 2000 | 11:00 PM
raven350's Avatar
Car: '89 Pontiac Firebird
Engine: 5.7L
Axle/Gears: 10-bolt w/ 4.10 and Eaton Posi
Does anyone have any pictures of these headers installed?
Curious at to how much clearence there is and what the cars look like with them installed...
Sportsman II 72 CC heads, Pete Jackson gear drive, Performance Resources chip, Edelbrock 1 5/8" headers and Edelbrock cat back exhaust, hi-flow cats, Trans-go stage 3 shift kit, Vigilante 9.5" 2800 stall convertor, SLP cold air induction, SLP roller camshaft, 24lb ADS injectors, AFPR, 3.45 rear end gears, and other goodies...
raven.com
Old Nov 30, 2000 | 10:03 PM
RARE-ROC-Z's Avatar
DID YOU HAVE TO FABRICATE ANYTHING. FOR THE LONG TUBE RUNNERS.. DID THE BRAKE LINES.. STEERING COLOMN SHAFT. OR A/C HAVE ANY INTERFERANCE WITH ANY PARTS AT ALL AND HOW FAR DO THEY STICK OUT THE BOTTOM I WANT THEM BUT I HAVE BEEN HOUNDED THAT THEY WONT WORK.. SO PROVE THEM WRONG PLEASE.. THANKS A BUNCH
1990 IROC-Z L98 350 TPI
AFPR 49PSI, GUTTED AIR BOXES, K&N, RAM AIR, PORTED PLENUM, B&M SHIFTER, 3.23 LIMITED SLIP, DUAL CATS, STOCK SUPER TURBO EXHAUST, COOPER COBRA XST's
MUSTANGS...HAHA THAT IS HILARIOUS.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
italiano67
Dec 11, 2016 09:21 AM
87iroctheo
Dec 4, 2016 11:47 AM
formula_novice
Sep 5, 2015 03:58 AM
86iroc z Z28
Aug 21, 2015 10:37 PM
