Hooker shorties
Old Nov 2, 2002 | 07:44 PM
redrummer's Avatar
Car: '88 Trans Am GTA
Engine: 5.7L L98
Axle/Gears: 3.27 Aussie 9 Bolt
Hooker shorties
I can't make the passenger side header fit. From the top, the flange won't squeeze through between the block and the wheel well. From the bottom, I can almost get the thing to slide in, but it looks like the wheel well is sticking out about an inch too far for it to fit. Also, even if it were to fit, I'd have to switch to a mini starter because there's no way on earth it would slide down in there with the stock starter in place.
Does anyone know of any problems like this with the Hooker shorties?
Old Nov 2, 2002 | 07:50 PM
88Bravo's Avatar
Car: 1988 Pontiac Firebird, flat black
Engine: Stock 305 LO3
Transmission: Five speed
What shorties are you tring to get to fit? If they are the 2055's then all you have to do is bend the air tubes inwards. I didn't have that much of a problem. I installed them from the bottom.
Old Nov 2, 2002 | 07:54 PM
redrummer's Avatar
Engine: 5.7L L98
They don't have air tubes. I'll have to get back to you on the part number.
Old Nov 3, 2002 | 04:40 AM
Ezey Go's Avatar
I had that same problem.If you have the hooker comp headers then all you do is take out the right engine mount bolt and jack that side of the motor up a little.
Old Nov 3, 2002 | 06:29 AM
redrummer's Avatar
Engine: 5.7L L98
Ahhhhh! Thanks for that little tidbit. I'll try that. They are Comps.
Now, can I get some volunteers to come to Georgia to help me put it all back together?
Old Nov 4, 2002 | 02:20 AM
88Bravo's Avatar
My car was on a lift. With out the air tubes my headers would have been a lot easier to install. Just up from the bottom and a little force. Worked for me. Good luck.
Old Nov 6, 2002 | 09:08 AM
TBI305Camaro's Avatar
I got my hooker shorty in from the top without jacking the motor up. I had to remove the spark plugs, fan switch sensor, starter, flywheel cover and the top half of the AC heater box and it went in.
no green
Jan 9, 2016 09:22 PM
Johnny*G
Oct 20, 2015 12:37 PM
thekurlyone
Sep 30, 2015 12:54 PM
Zell1luk
Sep 29, 2015 10:36 AM
Night rider327
Sep 16, 2015 02:20 AM
