Headers,high flow cat, cat back?
Old Dec 11, 2000 | 07:53 PM
91FastBird60kmiles's Avatar
ok i have some questions and need some opinions. Ok, right now i have a TBI 305.
But, next spring or summer i plan on dropping in an emissions legal version of the ZZ. Soon i plan on doing my exhaust.
Im planning on goin w/ SLP headers, good high flow cat and hooker catback.
1.Should i go w/ the SLP's in 1 5/8 or 1 3/4?
2. Which high flow cat should i use in the $100-$200 range?
3. Any other suggestiong on the cat back?
Im planning on getting SLP's w/ the adapter to go to 3" cat, and full 3" cat back.
Do u now the part numbers for which cat i should use and also the numbers for the cat back?....It also has to be emissions legal and not obnokciously loud
Thanks, u guys (and girls) fukin rule!
Old Dec 11, 2000 | 10:14 PM
Black Beauty's Avatar
Car: 90 Camaro RS
Engine: 305 TBI
well....since your price range is so high on the cat...i would say get the best...random technology...its pretty close to 200....if you wanna spend less....other companies make em....mor-flo....dynomax....catco...check summit for those. cat back ay....not too loud?? dynomax isnt too loud. but with headers and a hi flo cat you gonna have some trouble stayin quiet....try dynomax. i like hooker personally....the headers too. if you mind is set on SLP get the 1 3/4 headers....they are emission legal and are the same price as the 1 5/8 only they are better....especially since your gonnna upgrade to a 350...you may lose some torque with the 305 and 1 3/4 but itll pay off with the 350. hooker makes less expensive emissions legal 1 5/8 if you wanna go that route. good luck
Rick
90 Camaro RS 305 TBI
400 small block, Hooker 1 5/8 shorties, Random Tech Cat, Hooker aero chamber cat back on the way!!
TH700-R4 with Trans-Go shift kit (corvette servo on the way)
MacEwen Motorsports White Gauge Overlays
14" K&N X-Stream Open Element
GTS Headlight and Taillight covers
5% Limo Tint all around
Classic White Chevy Bowtie sticker on rear window
http://www.geocities.com/esvalenz
Man if my camaro were a rice-rocket all those mods would give me what...easily 50-60 hp!!!
Old Dec 11, 2000 | 10:59 PM
Whats the part # for the hookers?
any other suggestions and part#'s?
Old Dec 12, 2000 | 03:12 AM
Car: 90 Camaro RS
Engine: 305 TBI
the # for the 1 5/8 shorties are 2055. IRS has me for 150 w/o AIR, 200 w/ AIR. i think. they come with a y pipe too. i think they equal or surpass SLPs personally....they have been around since the 60s. the cat back is 16822....well that is the cheapest one...and if you replace the cat...that is the one to go with. its cheaper (200) and can be welded to the new cat you get. the others are 16823 and 16821 i beleive. those are around 259. good luck again.
Old Dec 12, 2000 | 10:23 AM
hey, thanks allot
Also, will i have to coat those hookers?
how much will it cost?
theyll pass emmisions...right?
Anyone else have any other suggestion?
thanks, u guys rule!!!
Old Dec 12, 2000 | 02:28 PM
Mo's Avatar
Mo
I think I'm going with the hooker shorties as well, as long as you get the ones with air they will pass emmisions.
I am planning on geting them coated, I found a place that i'll do it for 150, seems worth it to me.
90 IROC 5.7l (L98)
ram air, K&N's, air foil,Flows
LIKE A ROC
Old Dec 12, 2000 | 05:17 PM
Dan87IROC-Z's Avatar
Since its a 350, you'll for sure want the SLP 1 3/4" (wish I had gotten them). TPIS sells the Random Tech cat for $213. And I have been very happy with my Hooker Cat-back, and it set me back $260 from Jegs. I would stay away from the Dynomax, but along with the Hooker the packages from Edelbrock, Random Tech and a the Flowmaster American Thunder systems are great.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission with 2.77:1 Rear End
Current Mods: Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip with 160* Thermostat, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET : 14.32 @ 97.7mph
(corrected for elevation)
Soon to come: LT4 HOT Cam, Air Flow Research 190cc Heads, 2800 RPM Stall Converter and SLP 3.70 Rear End Gears.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
lakeffect2
Aug 23, 2015 08:44 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
drathaar907
Aug 6, 2015 04:20 PM
