This is what edelbrock has to say about gaskets, for there headers.
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
I would use Fel-Pro or Mr.Gasket, gaskets
And use Permatex Ultra Copper silicone.
With this it will never leak again.I would not use the aluminum or copper gaskets.
They standard header gaskets and Ultra Copper works great
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Taylor Spiro-pro wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
That's fine, just remember if you do like I did originally, and use the header kit's rubber donut gaskets, you're outta luck when it's time to replace, or heaven forbid you have a leak. Go to meineke or somewhere similar and buy steel ones, you'll thank me later.
Dan Young
1995 Z28/M6
Groton, CT
1985 Z28/A4
(Prospective purchase)
Dan Young
1995 Z28/M6
Groton, CT
1985 Z28/A4
You'll never get those donuts off your y-pipe, they melt to it, we had to use a blowtorch and cus for about an hour to get them off mine, the steel ones cost more, but they are reusable and have a great seal, lets you torque down on the bolts to your desire. Just a recommendation. There's a lot of heat created there.
Dan Young
1995 Z28/M6
Groton, CT
1985 Z28/A4
Dan Young
1995 Z28/M6
Groton, CT
1985 Z28/A4
efiguy
Sep 27, 2015 01:30 PM
Night rider327
Sep 25, 2015 04:47 AM
