my cat clogged?
Old Nov 13, 2002 | 10:36 AM
ninjairoc's Avatar
Car: 1986 Camaro IROC-Z
my cat clogged?
Could a clogged cat be causing hesitation in my acceleration?
Old Nov 13, 2002 | 10:37 AM
ninjairoc's Avatar
my car runs good when it is cold, but runs bad when it is at a hotter temperature. I heard it could be the cat. If it isn't what else could it be?
Old Nov 13, 2002 | 10:41 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Yes, a clogged cat will cause loss of performance, also the car may run a bit warmer.
At nite let the car get up to operating temp and look at the cat to see if it is glowing.
Old Nov 13, 2002 | 01:20 PM
Jekyll & Hyde's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
Yes he means glowing, it will be very red. You will not be able to mistake it.
LT1Formula
Oct 8, 2015 08:34 PM
jaridjohn
Oct 5, 2015 07:01 AM
