Header installation
Old Jan 12, 2001 | 08:00 PM
84 Bird's Avatar
Header installation
I am planning on getting hooker headers for my 84 Firebird. Does anyone have any experiance with them. How hard is it to install? Any problems with them leaking? Any comments would be apprieciated. Thanks
Old Jan 12, 2001 | 08:05 PM
Dan87IROC-Z's Avatar
I have the TES Headers, so I assume the Hookers are similar. They are a real bear to install because there is hardly any room to work, its hard to fit wrenchs into places to tighten bolts and everything. It took me the better part of a long weekend. Some of the work will have to be done from underneath the car, so you will need to raise it either with jack stands or ramps (like I used).
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission with 2.77:1 Rear End
Current Mods: LT4 Hot Cam, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip with 160* Thermostat, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
Old Jan 12, 2001 | 08:16 PM
Black Beauty's Avatar
Car: 90 Camaro RS
Engine: 305 TBI
dumb question but ive never seen it discussed....are u supposed to use any RTV or sealant of any sort in conjunction with the header gasket?
Rick
90 Camaro RS 305 TBI
400 small block, Hooker 1 3/4 LTs, Random Tech Cat, Hooker aero chamber cat back on the way!!
TH700-R4 with Trans-Go shift kit (corvette servo here...but not installed yet)
MacEwen Motorsports White Gauge Overlays
14" K&N X-Stream Open Element
GTS Headlight and Taillight covers
5% Limo Tint all around
Classic White Chevy Bowtie sticker on rear window
http://www.geocities.com/esvalenz
Man if my camaro were a rice-rocket all those mods would give me what...easily 50-60 hp!!!
"Just because I've done it, doesn't mean I knew what I was doing!" - Me
Old Jan 13, 2001 | 10:02 AM
Blade's Avatar
NO !!
sweet_87_iroc
Sep 25, 2015 10:01 PM
Wesly_66
Aug 26, 2015 09:55 PM
mdtoren
Aug 23, 2015 12:52 PM
theurge
Aug 21, 2015 12:46 PM
drathaar907
Aug 6, 2015 04:20 PM
