Project Research
Project Research
Maybe some of you have seen my posts going around, maybe not. Here's the deal. I'm in the process of planning out my 400 sbc build up. My goal is 450-500HP/TQ. Since this is the exhaust forum, you know what's coming... What kind of exhaust should I be looking for? Will a 3" cut the mustard or do I need to look into a 4"?
If the 3" will work, then I was stuck between SLP and Borla. Both are SS. SLP is cheaper. Borla seems to get praise upon praise here. Comparing the SLP to the Borla with your plate of choice. Which is louder, which has the deeper rumble, and which has that wonderful roar?
If I have to go 4", what do you recommend? Full custom, or are their companies that make good systems. SS would deffinately be a huge preference due to the wonderful winter corrosion experienced here near Chicago.
What about headers, will the 1 3/4" be acceptable? Recommended cat?
Hooker 1 3/4" long-tube SuperComps, Mufflex mandrel bent 4". If you must run a cat(s), Random Technologies is most reputable. www.mufflex-performance.com www.randomtechnology.com
85 calif. iroc
383/A4
9" rear
85 calif. iroc
383/A4
9" rear
Hi, I have a setup putting out similar HP #'s. Alot of people on here will tell you 3in is enough, and their proof is in the fact that there are 9sec TTA's and such running single 3in. But others will tell you it is not enough, I have not seen their proof yet. AS far as headers, everyone on here is wild about SLP's, I have not heard a complaint about them. Good Luck
Black 89 IROC...Mods: 355, 10.5:1 comp, Big Solid Crower Cam, TFS heads, Victor Jr, Holley, and a 5 spd...
Wow, you're putting out similar numbers with a 355? Or do you have another car? I also saw that you live in California, so you have some of the strictest emissions. Is your car also carbed? If so, how do you pass emissions? That's my big thing, I'll go for more power if I can, but I need to pass emissions. I was planning on getting a miniram, even though I love carbs(so simple to work with). Also, I've been recommended a tremec tranny, which is rated up to 525tq, If I were to go over that, say near the 600 range, what kind of tranny would I then be looking at?
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The best smog legal headers are SLP's, in my opinion. They're your only choice for 1 3/4" smog legal headers too.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.25 @ 107.18 MPH
Southern California
LT1Formula
Oct 8, 2015 08:34 PM
