Smog System Removal???
Old Nov 16, 2002 | 02:54 PM
86TransAMsbc305's Avatar
Car: 1986 Pontiac Trans Am
Engine: LG4 305
If I take the entire smog system out of my car will the computer or the performance be affected?...... I have an 86 Trans Am 305cid LG4, OD 700R4 Trans, with a carb.
Thanks,
Richard
Old Nov 16, 2002 | 03:28 PM
88Bravo's Avatar
Car: 1988 Pontiac Firebird, flat black
Engine: Stock 305 LO3
Transmission: Five speed
I have a LO3 and removed everything but the canister, EGR, and the pump its self. But the pump is not hooked up! What all are you going to take off?
Old Nov 16, 2002 | 03:39 PM
Engine: LG4 305
I want to take everything off....i might leave the canister.
Thanks,
Richard
Old Nov 16, 2002 | 04:43 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
read the tech articles from now on!
oh did you then use the search button!
it wont do anything. remove it.
Old Nov 18, 2002 | 12:42 PM
Parrydise7's Avatar
Is your car exempt from smog testing?
Old Nov 18, 2002 | 03:45 PM
Engine: LG4 305
Yes
Old Nov 18, 2002 | 06:51 PM
FLYNLOW92rs's Avatar
It says that if you remove the EGR system from the car you will have a continuous "Service Engine Soon" light...
As far as the A.I.R. Pump is concerned you can go ahead and remove that with no problems....
diana227vegas
Jul 8, 2016 12:27 AM
backtothe80s
Sep 5, 2015 12:39 AM
Street Lethal
Aug 13, 2015 08:28 PM
3rdgenparts
Aug 8, 2015 07:09 PM
mustangman65_79
Aug 7, 2015 09:55 PM
