what should I get
Old Jan 25, 2001 | 10:23 PM
84 t/a 5.0's Avatar
Car: 1984 Trans Am H.O.
Transmission: 700-R4
Axle/Gears: stock 3.73
what should I get
I have a stock 1984 t/a 5.0 with the L69 engine and automatic tranny. I was thinking about Edelbrock TES headers. Would they work with all the smog junk? Also, the exhast pipe past the cat has holes in it. what would you guys recommend getting for headers and exhast? The car has a lot of miles on it, so I dont know if the cat is still good.
kills
Old lady in 99 malibu
Old Jan 25, 2001 | 10:42 PM
MeanTA's Avatar
Go with the TES headers, but first fix that hole in the pipe go with a cat back system. Don't take the easy way out and use that bandage garbage either you casn start a fire that way. If your cat is shot and you don't have money to replace it gut it.
MeanTA
Old Jan 26, 2001 | 05:57 PM
84 t/a 5.0's Avatar
will TES headers work with O2 sensor?
Old Jan 30, 2001 | 09:05 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
Yes, they have all of the required emissions fittings for the O2 sensor and the air tubes, and will bolt right up to your cat. I second the recommendation of getting a cat-back exhaust too, as well as gutting the cat if you don't have to pass emissions.
Greg Westphal
'87 IROC 305TPI/A4
