is there any "easy way" to get on my header?
Old Jan 25, 2001 | 05:54 PM
Abe91Z28's Avatar
Ok, i've been putting in my edelbrock TES and the driver's side just plopped right in. Now for the passenger side, that is a different story.. i don't want to rip my whole car apart, but i'm wondering if there is any easy to get the header in there. the stock manafold came right out, but the header is being a PITA to get in.
So, i'm wondering if anyone here knows of an "easy" to put them in.
thanks,
-Abe
Old Jan 25, 2001 | 08:56 PM
ChrisR's Avatar
All I have to say is, "At first you don't succeed, get a bigger hammer." I have Heddman headers and the DRIVER side was harder. But if you haven't done so already, you have to remove the A.I.R. pump, and fittings, the dipstick, the spark plugs, maybe the starter motor (I had to) and fan sensor switch. Then it should just take some wiggling and swearing. Then you gotta put all that crap back together. If it is worth anything, I did it all in one afternoon, but I had everything planned out very carefully.
"An ounce of planning is worth 10 pounds of ...uh...yeah...well, I forget, but it's something."
take care
chris
1987 GTA 350,rebuilt in 1998. new heads, headers w/y-pipe, 45,000coil, accel plug wires and cap&rotor, k&n, b&m shift kit and trans cooler, modified mass airflow sensor, manual fans switch. No time slip.
1993 Bonneville SSE ALL STOCK. 95,xxx miles and stil counting...
Old Jan 25, 2001 | 09:45 PM
MeanTA's Avatar
The easiest way for me was to pull out the motor mount bolt on the side that you are trying to put on. Then jack up on the motor just slightly it will give you enough room to slide it right on down. My hands thanked me later.
MeanTA
Old Jan 26, 2001 | 06:55 AM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
I pulled the starter,plugs and the dipstick and carefully avoided the fan switch to get mine on. This recommendation came straight from Edelbrock tech dept.
Mongoose-NCTGA-1990 Pontiac Formula/305 TBI-700R4 with Edelbrock Performer TBI intake,TES headers,and STB,K&N,MSD-6AL,Holley laser shot coil,Accel Extreme 9000 wires,Jet Stage 2 chip,TCI shift kit with corvette servo,Richmond 3.73 gear with Auburn 3 series posi,no cat,SLP 3" cat back,Eibach sportline springs,Energy Suspension poly throughout,Lakewood LCA and adjustable panhard bar package,SSM subframe connectors,IROC wonder bar,Tokico 5 way adjustable struts and shocks,Autometer electric fuel pressure gauge,Alpine,JL Audio,MB Quart,92 GTA taillights,92 GTA aero wing and hatch,Steve Spohn LCA relocater kit,MacEwen White face gauges,84 T/A cold air induction air cleaner,Grant Formula GT wheel.
Old Jan 26, 2001 | 04:14 PM
wa90formula350's Avatar
I'll post my web site that has a helper section on header installs do not jack up the motor or you'll be sorry, if the only way you can get it in is by lifting the motor you need a engine hoist, here's the link not finished yet and anyone that cares to add anything let me know.
http://www.geocities.com/rx2man/Fire...rmula_350.html
Rob
1990 Formula 350
t tops, SLP headers, flowmaster 50 series
Old Jan 27, 2001 | 10:34 AM
Blade's Avatar
My TES header didnt go right in either. But I didnt have to jack up the engine, take off the starter or the oil pain or anything like that. I just took the valve cover off for more clearance, and beat it down in there with a BIG hammer! Seriously!
92 Z28 L98 350
Ported stock heads, XR270HR-10 cam, TES headers, Crane AFPR, Flowmaster catback, MSD ignition components, #24 SVO injectors.
Best ET 13.3@107 mph
"Take that auto, drop it in first, hold the brakes, stomp the gas and grin from ear to ear! :-)
Click here to see my car at Truspeed.org
Check out TruSpeed at http://www.truspeed.org
Check out the Bin Archive at http://www.truspeed.org/bins.html
Old Jan 27, 2001 | 10:00 PM
Abe91Z28's Avatar
th4nks al0t guys,
i pull3d the st4t3r and it they went right up in there. But, i have a question. On me head near the last spot for the header bolt there is two holes. The one closer to the engine, i can barely screw the bolt in. While the one on the back the bolt goes in fine, but the header is too far back then. is this two hole thing normal?
1991 Z28 305 TPI.
Mods: Hypertech Airfoil, gutted airboxes, K&Ns,polished 91' rims (they turned pink!), and all rear end bushings & tranny mout are energy suspension poly ones now
*MODS Currently being installed*: Edelbrock TES w/3" outlet y-pipe, 3" catco hi-flow cat, and hooker 3" catback w/areochamber.
MORE TO COME: Any suggestions on what to do next? I really want to try and make the 305 run 13s (i've mostly been doing basic repair to the car, but now most of its done i have money to mod!)e-mail me@ abraham_39@hotmail.com
Old Jan 30, 2001 | 09:14 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
Yep, I think every pass. side SBC head (maybe both sides?) has 2 bolt holes on the left side of the head. Since one of those holes wasn't used by the stock exhaust manifold but is used by the header, I had to run a tap through it to clean it out so that I could get the bolt in. I think the bolt hole the header uses is closer to the front of the engine, so you might need to clean out the threads with a tap...
Greg Westphal
'87 IROC 305TPI/A4
Rousseau92maro
Feb 1, 2016 05:12 PM
redformula88
Oct 14, 2015 06:08 PM
Chad Speier
Sep 24, 2015 12:32 PM
armybyrd
Sep 21, 2015 10:28 PM
hdis2002
Sep 8, 2015 02:52 PM
