Which are the best headers to install in my V8 350 TA?
Old Feb 8, 2001 | 08:59 PM
Jims83TA's Avatar
I have a 1983 V8 350 4 bolt main engine. I have a mild cam(Lunati) and a shift kit. I was thinking about replacing my headers and exhaust. I was thinking about putting in SLP headers, and flowmasters. What size headers should I put in my car? Also, what are the best headers to put in my car? I dont want to spend too much. I heard that SLP and Hooker were the best. Any suggestions? I dont want to spend too much. Thanks.
Old Feb 8, 2001 | 10:12 PM
The ODB's Avatar
The good ones cost some money.
I would say Hooker Super Comp full-lengths are the best, followed by the SLP stainless. Both are 1.75" primary, but the Hookers have 3" collectors compared to the SLP's 2.5"
There are some others out there very similar and probably cheaper... MAC, Headman, Walker, etc..
good luck & hope you like what you pick
Old Feb 8, 2001 | 10:20 PM
Slush92RS's Avatar
Car: 92RS
Engine: LS 402 inwork
Transmission: TH350
Axle/Gears: 10 bolt,3:73's
I had the SLP's but got rid of them because they interfered with my angle plugs. I switched to the Hooker long tubes, even though i haven't received them i'm really sure they will increase my perfromance and not fry my wire boots. Hey ODB you like your long tubes, and did you have any problems with them going in??
White 92 RS,388 cu.in.N/A
3.73 gears,auburn posi
Best 60 ft : 1.97
Best 1/4 : 12.679
Steve Spohn
Rear Suspension
Autometer guages
Extremely Loud Stereo !
Driven Daily
HOOKER LT's SOON!!! & 4 inch Exh.
Old Feb 8, 2001 | 10:34 PM
The ODB's Avatar
I run the SLP shorties. My friend Shawn ran the Hooker longtubes. They made big power but there were problems going on. He had clearance problems with the stater (required a mini-starter), and with his frame-rail (required grinding). He also removed the bellhousing ears from his 700R for clearance (be careful when doing this to not leave a rough surface which could form cracks).
Basically they were a pain, but performed super.
ODB
Linson
Oct 24, 2025 02:00 PM
Pac J
May 17, 2020 10:44 AM
cheesehomer
Dec 31, 2015 08:48 AM
Bradsaundry
Oct 7, 2015 04:35 PM
Zell1luk
Sep 29, 2015 10:36 AM
