SLP headers...best way to install fan switch without burning it??
Old Feb 14, 2001 | 01:24 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
as you can see in teh picture above, teh fan switch comes pretty close to the headers tubes. (and its broken, but thats another problem..) what is teh best way to fix this problem? the wire comes REALLY close to teh tube and i am afraid that it will burn. i also dont want it to look like crap. what do you guys recommend?
there is an "open" hole on teh driver's side head, which i could probably move the switch to, but i dont know if thats possible.
any ideas???
-brian
1991 Camaro RS - Ultra Blue Metallic, T-Tops
GM 350 HO Crate Engine - Vortec Heads, Edelbrock Intake, Holley 670 CFM TB, Edelbrock Water Pump, March Pulleys, MSD 6AL, Blaster Coil, 8.5mm Super Conductors, Cap and Rotor, Rapidfires, Hypertech Fan Switch & Chip, SLP 1 3/4" Stainless Headers, 3" Cat Back, Flowmaster 40 Series
700R4 - 2,400 Stall Converter, Vette Servo, Shift Kit, B&M Super Cooler
GM 10 Bolt -coming soon Auburn Pro Series Differential, Richmond 3.73s
Brian's 1991 RS Central NY F-Body Association
Join the Third Generation F-Body TBI Web Ring
z28boy@twcny.rr.com IM name: Z28 Boy
Old Feb 14, 2001 | 01:37 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
We just talked about this on the f-body.org [3] list. The suggestion was to either use the fireproof boots that come with the SLP install kit, or reverse the fan switch and temp gauge sensors, like you said. (the open hole should have the temp gauge sensor in it)
My SLP 1 5/8" headers I didnt have any problem with, but I guess I will have this problem too when I put my SLP 1 3/4" headers on this weekend.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Feb 14, 2001 | 02:12 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
yeah i knew it was on there, but i was looking for some more suggestions...thanks.
-brian
Old Feb 14, 2001 | 06:28 PM
Mo's Avatar
Mo
you could get an adjustable fan relay and use that instead, but i'm sure ther's gotta be a easier way.
90 IROC 5.7l (L98)
ram air, K's, air foil,Flows
LIKE A ROC
Old Feb 15, 2001 | 03:11 AM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
Did you get the installation kit with it? It comes with a 90 degree elbow for the fan switch.
1989 IROC-Z, ZZ3 shortblock with some bolt-ons.
13.20 @ 108.69, 2.2 60'
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
The_Phoenix
Feb 4, 2016 07:10 AM
dcbsracing007
Aug 18, 2015 07:24 AM
TA8487
Aug 16, 2015 12:21 PM
