Alternative header treatment?
Old Feb 5, 2001 | 11:25 PM
PONTIMANIAC 90's Avatar
Car: 1990 Formula
Engine: treefitty
Transmission: stick
I'm planning to buy the cheapest headers possible and I don't wanna ceramic-coat them.Also I don't need them to look good and I don't need them to last forever, simply because I'm not gonna last forever.lol
What are some alternatives? Is wrapping a good way to keep away rust?what about high-temp engine paint?Are there any other methods?
Thanks in advance.
Mike
1990 Formula
Factory:WS6-TPI-305/Dual Cat/5 Speed.Aluminum Drive Shaft.
Mods:SLP air foil,K&N Filter,All Accel ignition parts,Hypertech Thermomaster chip,Stat,Fan switch.Flowmaster 3" Cat-back exhaust,TB coolant bypass, Centerforce clutch.
Old Feb 5, 2001 | 11:45 PM
The ODB's Avatar
nope wrapping or paint is no good for keeping rust off cheap headers.
A company called Tech-Line makes some do-it yourself coatings that you can bake on in your oven. That might be what you're looking for. I'd say give them a call and see what they say.
Old Feb 6, 2001 | 12:14 AM
88blkiroc's Avatar
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
Wrap kills headers by trapping water and heat and corroding the header. id just ceramic coat them and be done with it. or you can powder coat them too
Old Feb 6, 2001 | 02:42 PM
Mo's Avatar
Mo
www.por15.com
look for por 20 you can even brush it on if you want, not too expensive either.
90 IROC 5.7l (L98)
ram air, K&N's, air foil,Flows
LIKE A ROC
Old Feb 13, 2001 | 09:18 PM
Car: 1990 Formula
Engine: treefitty
Transmission: stick
Thanks for the ideas, fellas. I decided to go w/TES.It seems that TES instals easiest according to my readings of many posts/archives.
Anyway, besides sand blasting is there another, easy way to get the factory paint off?
Solvent of sorts?
Old Feb 20, 2001 | 09:35 PM
Car: 1990 Formula
Engine: treefitty
Transmission: stick
to Mo
I ordered this Por20 stuff. Did you use it yourself? I preped the metal and paited it on(2 coats) It doesn't say you have to bake it. Just that it will cure if exposed to 300-up heat. It should cure from the exhaust heat, I think. But unless it cures to the desired hardness, some might scrape off during install of headers.
I'm gonna call them tommorow but I'd like to know what your experience w/the stuff was and how you went about it.
thanks
Hotrodboba400
Dec 10, 2019 07:07 PM
Twin_Turbo
Mar 14, 2016 10:10 PM
Chad Speier
Sep 24, 2015 12:32 PM
1Aauto
Sponsored Vendors
Sep 8, 2015 11:14 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
