Which gasket for edelbrock TES headers?NEED HELP!!!
Old Feb 19, 2001 | 07:16 PM
vortech305's Avatar
The 305 TPI has 88' corvette heads and im installing edelbrocks TES headers. I ordered the the complete FELPRO gasket set and it included header gaskets. Which should i use the Felpro header gasket or the gasket that came with the edelbrock TES headers.
92' camaro
New 305 block TPI conversion, Forged parts all around,Edelbrock intake,ported plennum,ported corvette alluminum heads accel cam,52mm throttle bodie, SLP runners,ford SVO 19lb injectors,fuel regulator,cloys timing chain, comp alluminum roller rocker arms and pushrods msd 8.5 mm wires hypertech coil and plug, Edelbrock TES headers, free flowing catalytic converter and a 3 ich force II flowmaster exhaust system.
Soon to come!!!
Procharger system 12lbs o boost.
Favorite quote: "where ever u go, there u are"
Old Feb 19, 2001 | 07:42 PM
CamaroMike's Avatar
Go with a good 1 5/8" ROUND header gasket. The Edelbrock gasket will block the exhaust ports on your vette heads.
84 Camaro ZZ4 with HOT cam. 1.88 60' (12.98 @ 105MPH E.T.)
Other Mods: You name it and I have probably changed it.
2001 Dodge Ram Quad Cab 5.9L 4*2
The Bowtie
ASE Certified Auto Tech
LIVE AND DIE BY THE ALMIGHTY BOWTIE!
Old Feb 19, 2001 | 09:40 PM
The ODB's Avatar
yep
Old Feb 19, 2001 | 10:21 PM
vortech305's Avatar
So in other words stick with the felpro gasket. The felpro was ordered for a stock 305 TPI so im guessing it was made for the 305 cast iron. Is there a difference.
Old Feb 20, 2001 | 11:12 AM
kevinc's Avatar
Car: 1982 Z28
Dude, you have both the Edelbrock and FelPro gaskets right there in front of you...and you're asking the world how they differ??
Hold 'em up and compare. Lay 'em over the exhaust ports, put a couple of bolts thru to hold 'em in place and see which one fits better.
Do some work man, it won't kill ya.
1982 Z-28
See http://www.mycar.net/mafb/registry/detail.cfm?id=276 for details
Old Feb 20, 2001 | 02:30 PM
vortech305's Avatar
I just needed a little insentive
92' camaro
Soon to come!!!
Old Feb 20, 2001 | 04:52 PM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
I used SCE Copper gaskets on the TES's on my 305. They worked great so far. Stage 8 bolts too.
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
http://members.aol.com/j007golden/91firebird.html
For info on certain parts or mods go to the site below
http://members.aol.com/j007golden/modeval.html
Old Feb 21, 2001 | 01:38 AM
Baron's Avatar
DEFINITELY Fel-Pro...that's what I've got on mine. I've heard horror stories of the stock Edelbrock gaskets blowing after no time...and most anybody that tells you they won't has either never had experience with them or has had them on for less than two weeks. If you're gonna do the job, do it right the first time...going in to replace a blown header gasket is NO fun...you'll be happy with Fel-Pro. Good luck!
'89 RS LO3- 140,000 miles
14x3 K&N Open Element
Ram Heavy Duty clutch
Edelbrock TES (Jet-hot coated)
Catco cat
Edelbrock 3" Cat-back
Pioneer DEH-P77
Dual .50 caliber machine guns just under ground effects
Coming:
KYB shocks
Edelbrock Strut Tower Brace
South Side Machine subframe connectors
When your buddy reaches for a 10-pound sledge and says "I think we're gonna have to modify the floor pan, okay?" the answer is NO.
Old Feb 21, 2001 | 02:25 PM
vortech305's Avatar
Thank u Baron thats all i needed, Someone to say Felpro or Edelbrock but i get stories. So thanks anyway ill go with the felpro.
92' camaro
Soon to come!!!
Hotrodboba400
Dec 10, 2019 07:07 PM
toronto formula
Sep 10, 2015 07:31 AM
hdis2002
Sep 8, 2015 02:52 PM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
