hooker cat-back
Old Feb 25, 2001 | 02:39 PM
jester731's Avatar
hooker cat-back
I plan on buying a hooker cat-back system in the near future and i was wondering how difficult is the instillation and does it have to be welded? thanx
Old Feb 25, 2001 | 03:37 PM
steven's Avatar
Well the cat back hooks right up to the old cat, and if you don't want to, you won't have to weld, you can clamp it all, but i've heard that welding it, will make it sound better. if you don't know how to weld, go to a local shop, they will do it for pretty cheap most likely.
191(3.1)V6 1992 Pontiac Firebird,K&N drop in filter, bosch patinum spark plugs, Pioneer reciver, kenwood 4x6's, sony xplod 6x9's, two kenwood tornado 12's with a 300 watt jenson running them, check it out at www.geocities.com/my_92firebird
Old Feb 25, 2001 | 04:03 PM
jester731's Avatar
thanx does the system come with the clamps or do i have to buy them separately?
Old Feb 25, 2001 | 06:50 PM
Troy 85Z's Avatar
Car: 85 Z
Engine: Edelbrock Injected 350
Axle/Gears: 3:42 LS1 Posi
The kit comes with all of the hardware to mount it, clamps and hangers. I clamped mine together and so far I don't have any leaks and it sounds fine. Its only been on about 3 months but so far so good. I'm not sure how well it connects to the existing cat, I had to make an offroad pipe, but I assume it should work fine. The hardest part is getting the old system out but it's not to bad. Good luck
Old Feb 25, 2001 | 07:09 PM
jester731's Avatar
thanx that doesn't sound to bad
how much louder than stock is it?
Old Feb 25, 2001 | 07:31 PM
Dan87IROC-Z's Avatar
Its noticeably louder than stock depending on what other exhaust mods you have and what size cam you are running. I have headers and a big cam so mine is really loud. But my friend with his 85 Z28 its louder than stock, but not too loud. IMO, its the best cat-back of the medium priced ones!
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 Hot Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
7.5" 10 Bolt with 3.42s soon to come!
no green
Jan 9, 2016 09:22 PM
thekurlyone
Sep 30, 2015 12:54 PM
Chevykid810
Sep 28, 2015 12:57 PM
ssgt usaf
Sep 21, 2015 12:45 PM
Tylermcclinton
Sep 17, 2015 07:50 PM
