SLP headers on ZZ4 engine
Old Feb 26, 2001 | 10:31 AM
BairsZ28's Avatar
I plan on installing the ZZ4 conversion kit in my '84 Z28 and wanted to know if the SLP headers are the way to go? Also, what size should I get, the 1 5/8 or the 1 3/4?
Old Feb 26, 2001 | 12:59 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Yep, I've got SLP headers on mine and they're great. Which ones to get depends on your plans for the car. If you're a street driver, get 1 5/8". If you're a racer, get 1 3/4". If you're gonna put in a larger cam, get 1 3/4".
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Feb 27, 2001 | 10:22 PM
BairsZ28's Avatar
I plan on putting bigger valves in the heads or putting different heads on but that won't be until probably until next year. What would be the difference between the 1 5/8 and the 1 3/4 on the stock ZZ4 and then when the engine is modified?
Old Feb 28, 2001 | 05:46 PM
Kevin91Z's Avatar
Dont bother with bigger valves in the ZZ4 heads, its not worth it.
I dont think anyone has done a dyno comparison between SLP 1 5/8" headers, and SLP 1 3/4" headers. I switched on mine but I did a lot of other mods at the same time. SLP recommends 1 3/4" headers for a 350 or larger engine, and 1 5/8" for a 305 engine. If you've got plans for different heads and cam next year, get 1 3/4" headers now. You wont lose anything now, and you'll gain more after you swap.
italiano67
Dec 11, 2016 09:21 AM
fonzie85
Exterior Parts for Sale
39
Mar 16, 2016 07:07 AM
Reddeath210
Oct 6, 2015 08:20 AM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
