I am about to order header gaskets, But i need to know which ones are the best .
Old Feb 27, 2001 | 05:00 PM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
I need to know which ones seal the best and last the longest for the edelbrock tes 1 5/8's, Also is there anything I should do when installing the gaskets? is there any sealent I should buy? thanks
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Taylor Spiro-pro wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
Old Feb 27, 2001 | 06:22 PM
85ZZ4TPI's Avatar
The headers should have come with gaskets? otherwise go with fel-pro.
Old Feb 27, 2001 | 06:46 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
i think i am going to try and use the "dead soft" aluminum gaskets. the concept of them are good, with them not blowing out i mean. has anyone used these?
Wide Open Till You See God...Then Brake
Old Feb 27, 2001 | 08:06 PM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
I used the SCE Copper Gaskets on my TES's and they worked great. I wouldn't use the ones that the TES's come with, I heard they bust easily.
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
http://members.aol.com/j007golden/91firebird.html
For info on certain parts or mods go to the site below
http://members.aol.com/j007golden/modeval.html
Old Feb 27, 2001 | 08:08 PM
BLACK Z's Avatar
Car: 86 Z28
I have had the headers on the car for 2 years now, It is just that the last time I swapped motors the ones I put on where just regular manifold gaskets and I think they are leaking.
Old Feb 28, 2001 | 05:31 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
The aluminum gaskets are the best! Better than copper on sealing irregular surfaces. 12,000 miles on mine without a retorque. Skimping on gaskets now means a big waste of time and money in the furture since changing gaskets on 3rd gens is a PIA. Percy's dead soft for SBC square port around $35 in Jegs/Summit
'88 Camaro RS 2.8L
'88 Formula 350 (Too many mods to list...)
Old Feb 28, 2001 | 10:07 PM
rhawki's Avatar
Agreed about the alum gaskets. Got a set of Percys two years ago and haven't touched them since - with paper it was every couple months. They won't shrink or crack or blowout, but are still soft enough to conform. Dunno about the coppers...
-Rich
1992 Trans Am
May 10, 2023 07:19 PM
92projectcamaro
Jan 18, 2016 08:00 AM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
hectre13
Sep 8, 2015 03:38 PM
