TRUE DUAL EXUAST......
Old Feb 26, 2001 | 11:22 PM
Drufire's Avatar
Am I the only one with a dual ex' set up on a 82-92 f body??
I am interested in how you did your dual ex'
Drive A BowTie And Leave The Suit At Home!
Old Feb 27, 2001 | 02:40 AM
3.1 firebird's Avatar
(muffler)
______
| ]==============(pipe)
=======[______| | ]====(pipe)
=================[______|
(muffler)
I was thinking about doing something like that. the mufflers would be offset inlets and outlets. I was hoping that I could put both of the mufflers wedged against eachother , like in my diagram, under the passneger side then run the pipes under the axle, then exit out back in the stock locations.
Old Feb 27, 2001 | 02:55 AM
doh!
[This message has been edited by 3.1 firebird (edited February 27, 2001).]
Old Feb 27, 2001 | 06:58 PM
gsmann's Avatar
I have it two. two - 2 chamber flowmasters side by side where the cat used to be. piping to go all the way back so it looks stock. all piping tucked higher than the stock 3" pipe, so i never scrape.
a-1 muffler shop in morgan hill, ca. did the job. tell him gary with the transam sent you. should give a good price.
Old Mar 2, 2001 | 10:51 PM
Digger's Avatar
I have headman headers and I am putting dual exaust on. It is going to have glass packs and dump in front of the back tires. But I have to make a special crossmember for the tranny.
Old Mar 4, 2001 | 04:15 PM
karstenkurtz's Avatar
I have/had true dual exhaust but I'm getting a different exhaust now (my car is in the shop for it right now).
Karsten
86 IROC-ZZ4... too much to list.
Old Mar 4, 2001 | 10:35 PM
Hummer's Avatar
Car: 1986 Z28
Transmission: 700-R4
Anybody know...what's the difference(if any) in HP with the true dual? I've just got flowtech hedders y-piped into my Dynomax muffler (no cat), but I was thinking of switching to the H or X pipe setup. Any opinions?
Take 'er easy, and if
she's easy, take 'er twice!!!
Old Mar 4, 2001 | 11:28 PM
The ODB's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Hummer:
</font>
Factoring in full length headers, larger 3" collectors, two expansion chambers, and an H or X with two high flow mufflers you could probably see about 5 or 6% increase in power depending on engine size & RPM range.
mattcanty
Oct 12, 2015 11:08 AM
paul_huryk
Oct 1, 2015 04:27 PM
