hooker long tubes and burnt plug wires
Old Mar 11, 2001 | 06:51 PM
bad camaro RS's Avatar
any sleeves or anything i can buy to slide over boots that can take the heat
Old Mar 11, 2001 | 06:58 PM
IROCeastTN's Avatar
I use the DEI exhaust wrap. It works really well. Just soak it in water and wrap the hedder tubes. It reduces underhood temps alot.
later, eastTN
88 irocz fresh 350 tpi eibach springs, weld draglites, 1 3/4 hedman shortys, flow master, march aluminium underdrive pulleys, T.B. coolant bypass, accel 300+ race wires, 180 thermostat, accel flow booster, 2 lower walls removed from stock uppper plenum, 700r4 with 2500 stall, B&M shift kit, corvette servo, kevlar frictions, K&N filters, emissions delete
eightsixseven
Dec 16, 2024 01:50 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Infested
May 22, 2018 11:56 PM
Winchester1094
Aug 18, 2015 10:23 AM
