Header Wrap
Old Dec 12, 2002 | 09:22 AM
84CamroHO's Avatar
Header Wrap
Just wondering if any of you guys wrap your headers and if so for what reasons? I can see that you do it so everything doesn't melt but the companies claim "performance" gains is this true?
Old Dec 12, 2002 | 10:00 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
They'll keep the underhood temps down, thus increasing the amount of cold air getting into the engine.
There are however negative sides to header wrap. I've researched it, and though if done right (which may be tricky), I would never use wrap.
Ceramic coating for me.
Old Dec 12, 2002 | 10:48 AM
84CamroHO's Avatar
ceramic coating is awsome just looking to be real cost effective....what were some of the negative things you found out about the wrap?
Old Dec 12, 2002 | 12:58 PM
Car: 99 Formula
Axle/Gears: 342
Before someone jumps down my throat again, I have never used the wrap, but have read people's replies on here.
1. if not sealed properly can increase the rate of corrosion
2. any oil from leaks that drips on them can be a fire hazard, one guy's car actually caught on fire
I believe that's it, unless I missed something.
Old Dec 12, 2002 | 05:20 PM
92Transam's Avatar
Car: 91 firebird now
Transmission: 5 speed
Yea the coating is better, we wraped the stock cars headers then took the wraping off one day to replace it and they where rusted to hell. Ive also heard another reason to do this is to make the exhaust gas move faster out of the headers, ( something about hot gas moving faster than cold, so the hotter the better! )
Old Dec 12, 2002 | 05:34 PM
darbleinad's Avatar
Car: 84 Trans Am
proper prep and application of the wrap is key....do it right and they wont rust.
if you want to do header wrap,
here's the proper procedure:
https://www.thirdgen.org/techbb2/sho...&highlight=BBQ
Old Dec 12, 2002 | 05:36 PM
92Transam's Avatar
Humm I think I want to get some headers and wrap them for x mas now.
Old Dec 12, 2002 | 05:39 PM
darbleinad's Avatar
Car: 84 Trans Am
yeah if you are concerned about keeping under hood temps down, and cant afford to get the headers ceramic coated (no question that ceramic coating is better), header wrap is a great, cost effective alternative (if done right).
Old Dec 12, 2002 | 05:40 PM
92Transam's Avatar
I heard if you have both that ( heads coated and wraped), oh hell I don't remember I think it was about the heads breaking from heat or something.
Old Dec 13, 2002 | 04:40 PM
OnFiRe705's Avatar
92transam....i think what you were saying is that if you wrap and have the headers coated that they will rust and you might wind up with holes in the headers and not even know it. I read that somewhere....correct me if im wrong though.
OnFiRe705
Old Dec 13, 2002 | 05:14 PM
Car: 99 Formula
Axle/Gears: 342
OnFiRe705
Any header that is coated with ceramic shouldn't rust anytime soon, I would think.
Old Dec 13, 2002 | 09:24 PM
darbleinad's Avatar
Car: 84 Trans Am
you dont need the wrap if you have the headers ceramic or jet-hot coated
Hotrodboba400
Dec 10, 2019 07:07 PM
redformula88
Oct 14, 2015 06:08 PM
Chad Speier
Sep 24, 2015 12:32 PM
Accerrito22
Sep 5, 2015 09:34 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
