Which headers = easiest install?
Old Dec 14, 2002 | 08:15 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Four into ones I know are the rule b/c of the F-Bodys limited space, but of all the four tubes which one has the concensus been on ease of install? Also, would 'blockhugger' style headers be an option or do you think they might be a little dangerous as far as the crowded engine compartment - cause I know theyre intended for streetrods with little to no street driven accesories.
Old Dec 15, 2002 | 09:30 AM
heavy_chevy29's Avatar
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
i heard the edelbrocks slip right in. i think i going to get them or i'm still debating wether or not i should spend the money and get the coated SLP headers. im not to worried about installing them b/c my engine is out of the car.
Old Dec 15, 2002 | 11:41 AM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
My Accel's went in very easily. Connecting the y-pipe to the collector was a whole other story.
Old Dec 15, 2002 | 02:02 PM
likeistoleit's Avatar
Car: 87 Iroc
Transmission: Tremec Tko
My hedmans went in easy, I had to relocate the coolant tube on the left side though, Y pipe sucked to assemble.
Old Dec 15, 2002 | 07:28 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Heres the thing - I want an exhaust system that is brand consistent and more specifically I have my sight on Dynomax all the way - dymx jet hot coated 1 & 5/8, dymx super-cat, & dymx catback w/ one of thier mufflers.
I was looking at the dymx headers and thought they looked like a good snug set of 4into1 headers. Any of you know them to install easily? GMHTP mag said thier shop didnt have much trouble with them.
Old Dec 15, 2002 | 11:42 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
my edelbrock's were pretty easy to install. they went in without many problems. just a few scratches on a couple of the tubes.
my SLPs? don't even ask....
-Brian
Old Dec 16, 2002 | 10:58 AM
MdFormula350's Avatar
-Brian
what were the problems you encountered.. if you dont mind me asking.
Old Dec 16, 2002 | 11:48 AM
EvilCartman's Avatar
Car: '82 Z28
My Edelbrock headers went in easy, y-pipe wasn't bad at all.
Old Dec 16, 2002 | 12:27 PM
Black91Z28's Avatar
Car: 1991 Camaro z28
Engine: 350 Tpi
Transmission: 700r4 Auto
i got the hookers in my car very easy....the headers that is
Old Dec 16, 2002 | 02:15 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
well, they ar just plain bigger, which makes them harder to fit in the same spot. the primaries on my SLPs that i have now are 1-3/4". the WHOLE length of the primary. the edelbrock (junk if you ask me) ones are like 1-1/2" a lot of the time instead of the advertised 1-5/8". the passenger side ones for both went in pretty easily for me, but then again i dont have anything there (no ac, no heater hoses, no emmisons stuff), but the driver's side is a pain with both, and worse with the SLPs.
the SLPs also hit my steering shaft on the (if i remember right) number 3 cylinder tube. not everyone runs into this problem, but i did. it depends on a few things i guess...mainly the condition of your motor mounts.
the y-pipes on the two are similarly a pain in the butt to put on. once you do ita couple times though, you get used to it and it's easy. you just need the help of another person, or a small jack that you can use to position the pipes in the right spots while you tighten the bolts.
the SLPs are FAR superior product, without a doubt. the only person i would reccomend edelbrock's TES to is somebody who just wants headers, and doesn't plan on doing much else to the car. i just think that they are a waste of time and money if you plan on doing a lot of things downthe road. just my opinion, but if you look at the SLPs right next to the TES, you will probably agree.
-brian
Old Dec 17, 2002 | 09:48 PM
Black_Widdow's Avatar
Car: 05 GTO, 88 GTA, 98 SS
Heh, I've had my Hooker 2055's sitting in my room since JULY! I'm scared to try to put them on myself. Looks like a real PITA, especially without power tools. I might have to collect change until I can have my shop put them on. Can I do it in the driveway in a weekend?
Old Dec 18, 2002 | 09:38 AM
FyreLance's Avatar
Car: 00 TA, 91 Formula, 89 RS
well, they ar just plain bigger, which makes them harder to fit in the same spot. the primaries on my SLPs .... etc.
Your avatar rocks.
Old Dec 18, 2002 | 11:03 AM
Fast3rdGen's Avatar
i've only had edelbrock and hooker longtubes, and i must say that everything is easier with the long tubes. they have to go in from the bottom but they slip right through. tune ups take me a matter of minutes, not over an hour. plus no more burnt wires on the passenger side. i can't tell you how many wires i fried because the edelbrocks were so tight. and the y-pipe is a biznitch on em too.
Old Dec 18, 2002 | 04:01 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Old Dec 18, 2002 | 05:16 PM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
Originally posted by brodyscamaro
That bothers you in some way?
If the guy wants to run Dynomax parts and Dynomax parts alone, that's his prerogative. It's his car.
Old Dec 18, 2002 | 05:25 PM
Dirty Rob's Avatar
I almost choked when I read that, thank you very much
Old Dec 18, 2002 | 06:29 PM
there is nothing that anybody can do to their car that bothers me. i think that you shouldnt say i want the best exhaust system possible, but one catch it has to be all dynomax. what if the best headers arent dynomax, what if they are but the best cat is a carsound one? what if there was a magical new muffler that made more power then a dynomax? see, you are going to have to make compromises if you want a all dynomax exhaust. hooker does not make cats IIRC, so that rules out their headers and cat-back...
Old Dec 19, 2002 | 03:35 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Originally posted by FyreLance
Your avatar rocks.
haha, thanks man...i ran across that one day, and i had to use it.
-brian
Old Dec 20, 2002 | 03:15 AM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
The hooker 2055s fit right in from the top. I had my uncle help me with the y pipe and that was on in about 10 minutes.
Old Dec 20, 2002 | 10:08 PM
russkull84's Avatar
Car: blue 84 z28
Engine: mildly modified 350
My edelbrock headers were easy to install but I also had problems with them destroying plug wires. Good luck!
dutch930
Sep 11, 2015 06:58 AM
Wesly_66
Aug 26, 2015 09:55 PM
theurge
Aug 21, 2015 12:46 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
drathaar907
Aug 6, 2015 04:20 PM
