Anyone know if exhaust pipe is 2.5 stock???
I wanted to know if the stock exhaust pipe right after the cat but before the muffler is 2.5 inches? Thats what my mufflers' inlet and outlet are but the exhaust pipe looks bigger before the muffler than it does where it enters the muffler. Can anyone help me? I would really appreciate it
- Red '91 Z-28 350
- 700-R4 Trans
- T-tops
- no major power
gaining mods, K&N
Filter, Flowmaster
exhaust -series 80-,
exhaust cut-outs - Best E.T. 15.0@93mph, Will improve that 1/4 mile time this spring.
- www.
hardlineperformance.8m.
com
Car: 1991 GTA Convertible
If it's a TPI than the outer diameter of the pipe is 2 3/4" from the factory. If it's aftermarket stock replacement exhaust then it may be smaller.
1988 GTA 5.7L TPI Auto
355 ci. block,TPIS ZZ-9 Camshaft, SLP Headers, B&M Holeshot 2400 Stall Converter, 3.73 Richmond Gears
"Why ride a stang when birds can fly?"
http://www.geocities.com/thegta
But my Flowmaster muffler has a 2.5 inch inlet so does that mean the whole pipe from the the cat to the muffler is the same?
- Red '91 Z-28 350
- 700-R4 Trans
- T-tops
- no major power
gaining mods, K&N
Filter, Flowmaster
- www.
com
i used to have that muffler, it has a flare on the inlet. You have to cut that to the size a bit larger than the intermediate pipe and have it welded on. You can use adapters but they only last a couple of months, they rust very quickly.
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
You've got a 91 Z28 with a 350 engine and t-tops? Thats a rarity...
Your stock exhaust should be 2 3/4". Joseph is correct about the muffler. The shop who installed it should have correctly modified the muffler to fit.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.25 @ 107.18 MPH
Southern California
transaero
Aug 31, 2015 01:14 AM
